Members taintedelephant Posted May 5, 2015 Members Report Posted May 5, 2015 I just got a 1 pound dead blow hammer. I just wanted to give it try and see how it would work. I haven't done much with it, but I tried it out with a slot punch, and the best thing about it is that it is super quiet, and it punches way easier than that tiny 4 oz wooden hammer I had. Quote
electrathon Posted May 5, 2015 Report Posted May 5, 2015 I rarely use mine while tooling, but most always use it when basket weaving. It stops you from getting double imprints from hammer bounce. Wooden hammers are never a good choice. Quote
Members taintedelephant Posted May 5, 2015 Author Members Report Posted May 5, 2015 Yeah, I got the wooden one when I just got started, and only kept it because the poly and rawhide ones marketed for leather work are way overpriced. I think the dead blow was about $6. I figured I might continue using the wood one for stamping, since I don't do much anyway. Although I bet it would be good for letters, and 3d stamps. Quote
Members TinkerTailor Posted May 6, 2015 Members Report Posted May 6, 2015 Once with a smaller diameter metal punch about the size of a leather punch, I hit it so hard that the punch went through the face of the cheap dead blow and into the cavity inside and stuck there. Had to cut up the hammer to get the punch back. You may find the face mars pretty easily as well. It is a great light duty and cheap option however and you can go through 2-3 for the price of a crappy tandy mallet. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
electrathon Posted May 6, 2015 Report Posted May 6, 2015 If it is from Harbor Freight it has a lifetime warranty. Quote
Members TinkerTailor Posted May 6, 2015 Members Report Posted May 6, 2015 If it is from Harbor Freight it has a lifetime warranty. True, however there will be the fuel to get the new one, as well as the 50 bux in impulse buys that get me every time i set foot in those doors... (btw, for us it is princess auto.) Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members taintedelephant Posted May 6, 2015 Author Members Report Posted May 6, 2015 Yeah its from HF, I too can't get out of there w/o at least walking down every aisle. The trick with them is to know the difference between the tools and the tool shaped objects that they sell. I bought a lot of TSOs from them. total waste of money. Any way the hammer isn't the Mjolnir that I had hoped, but I still like it a lot, and way better than the wood one. Quote
Members chiefjason Posted May 9, 2015 Members Report Posted May 9, 2015 That's all I use to punch holes with, and occasionally set rivets. Used one for 3 years now, face is marked but still going well. If you do break one open it's usually full of very small lead shot. It will go everywhere. Quote
Contributing Member TwinOaks Posted May 9, 2015 Contributing Member Report Posted May 9, 2015 I drilled out the core of one of my wood mallets (drilled from one side, only) and back filled with #8 shot. Then I mixed fast set epoxy and the drill chips as a plug. I only use the undrilled side for tool contact, but the result was pretty good. My next foray was using a hole saw and making a bunch of 'donuts' from an HDPE cutting board. I stacked those on a long bolt, and held in place with a flat back t-nut. That result was excellent, but I still think a solid faced hammer/maul will perform better. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members TinkerTailor Posted May 10, 2015 Members Report Posted May 10, 2015 I drilled out the core of one of my wood mallets (drilled from one side, only) and back filled with #8 shot. Then I mixed fast set epoxy and the drill chips as a plug. I only use the undrilled side for tool contact, but the result was pretty good. My next foray was using a hole saw and making a bunch of 'donuts' from an HDPE cutting board. I stacked those on a long bolt, and held in place with a flat back t-nut. That result was excellent, but I still think a solid faced hammer/maul will perform better. You can fuse the discs together with heat. Look for the videos on milk jug mallets. Stack the discs in piece of pipe and heat it up in the toaster oven. They will fuse with a little pressure. You can get short lengths of various diameter steel tubing for a mold in the scap bin at a local muffler shop. Bring beer. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
