Seeing that TriFlow has been brought up in another thread as a lubricant for sewing machines, I'm just wondering how well it fairs in doing that task? If those that have experience could comment on how it compares to the clear or "white" oil many of us use. Having done a little research on the subject, I mixed a little STP in with my sewing machine oil and that has produced some very good results.
Having never considered TriFlow as a lubricant, hope those that use it can enlighten.
Regards,
Joe Esposito
www.hockeymenders.com
instragram: @hockeymenders.com
Triflow is a great teflon based lube. I do use it in the factory, just not on anything that even comes close to fabric, (rules out all the sewing machines). It, like most other lubes out there, stain. The best thing about Triflow, is the smell. Bananas.
The other issues when running machines at high speeds, is that lubes that are thinner, blow past shaft seals meant to contain sewing machine oil. On a slow moving leather machine, this is probably not an issue. On a machine running at high speed, it'd be everywhere except in the machine. Stuff is really slick.
As an aside, we use a really lightweight (3 oz) deer suede on Lycra equestrian pants. Even the sewing machine oil stains it and we have to replace it, so the machines in that line are wiped down twice a day.
Regards, Eric
I think tri flow is the best lube out there for use when bringing machines back to life. It will wick into anywhere and free up alot of stuck stuff. It is too thin however to stay inside things. It also may be thin enough that it cant be pumped by pumps with loose tolerances or wear. Plus its got nasty chemicals in it that you probably shouldn't get on your skin. I believe its designed with solvents to increase the wicking of the product, leaving thicker oil behind after the solvent evaporates. On the msds, it says it has parrafinic oils, i'm not a chemist but this sounds like parrafin oil. This stuff probably breaks down into wax again, or worse and could lead to gumming up over the long term. Just a thought. I wonder what 20 years of teflon buildup in a machine looks like?
"If nobody shares what they know, we will eventually all know nothing."
"There is no adventure in letting fear and common sense be your guide"
Thanks for the info. So it sounds like TriFlow is not something that would be ideal for just basic machine lubrication. My machines operate at a very slow speed, so I'm just curious how often would the TriFlow need to be applied to maintain the proper level of lubrication? I guess my main interest is would using TriFlow in a slow speed machine extend it's life as opposed to using standard sewing machine oil?
Regards,
Joe Esposito
Not machinery or leather related, but triflow is all I use on my tri bike as well as my road bike. I've used it in all conditions from rain, snow, sleet, mud, hot sun, etc and it hasn't let me down yet!
You wouldn't use sewing machine oil in your car, so why try and use something different in your sewing machine other than what was meant for it?
Regards, Eric
Yeah, I found it in the bike world as well. I meantioned in another thread that is is alot more reasonable in the gallon jugs if you use it frequently. I know a gallon is a whole lot, but its good stuff and then you wont run out. Plus you can sell refills of the little bottles to your buddies for half price and still not lose money.....
Regards, Eric
In your position, i wouldn't experiment either, however alot of "industry specific" products are really just re-labeled generic product with a jacked up price. In the bike world, they sell these little tubes of spoke prep for building wheels. Its like 30 bucks for an ounce or two. Active ingredient? Linseed oil.... Lava flow bike chain oil? Straight up chainsaw chain oil. Tandy blue nitrile gloves for leatherwork - 6 for 5 bux, at the drug/hardware store 100 for 10 bux.... Most rusty bolt removers are mostly kerosene.
Also, bearings are bearings. Auto engines are pretty similar inside mechanically to sewing machines, bunch of cranks and rods and cam followers, and big v8s generally run in the same rpm ranges a sewing machine. Car engines and motorcycle engines use pump, splash and rarely wicking oil systems as well. I am willing to bet that there has been waaaayyyy more money put into developing better engine lubricants than better sewing machine oils in the last century. The new synthetic lubes may be the cats ass for sewing machines, who knows? I would actually be interested to know if the automotve synthetic oils can be removed from fabric easier than dino oil with your dry cleaning methods.
Edited by TinkerTailor
Tinker,
You have hit on the general premise of this whole thread, is there something that can do a better job of lubricating my machines? In a factory environment I can see where you stick with something that does the job for machines running flat out all day, everyday. However that said, it does not necessarily mean there is not something out there that may well be "the cats ass" for machines like mine. I have used Balistol in the past and have found it to work very well. Does a great job cleaning the running gears of older machines as well as lubing them. Wondered if TriFlow fit in there as well. Guess I'm just trying to think outside the box.
Regards,
Joe Esposito
Triflow is a great lubricant. It gets in everywhere and the teflon remains and lasts for a long time to keep lubricating. Years ago a friend used to distribute it and did demos with a chainsaw. They ran saws with no chain oil, just sprayed the bar with Triflow. You could use the saw for quite awhile without the bar getting hot. I think it would be excellent for manual lube sewing machines but wouldn't work with reservoirs or pumps as the the teflon would settle out and not go through the machine. Any drips could stain your work.
http://www.bound2please.com
Sewing machines:  3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
The reason nothing much has evolved in sewing machine lubrication is simple. There's been no demand to justify the R&D expense because what the industry worldwide is using still works.
If the industry standard oil can keep this two needle chainstitch running 8 hours a day since 1974, at 3000 stitches per minute then why bother? This machine fells 100 yards of cotton for flag stripes without stopping. It takes less than a minute to change rolls and restart. The machine is a Union Special 56400 P. It is entirely lubricated by a violent splash system that can easily throw oil 3 feet high with the top cover removed.
Regards, Eric
