This is made from approx 2.8mm leather and it has a suede patch which is pretty non slip on the shoulder patch. Finished with black polish and Lord Shearatons Leather Balm.
I leant a few more lessons along the way.
It was going to be brown, but had an accident with the black Edge Kote and had to dye it all black. I should have put a bit of polish over the brown first, then when adding the black Edge Kote, it would not have bled into the brown dye.
I measured the rivet holes using much thinner swivels than the ones I would normally use. So they are a little bit to close together.
The stitching took ages as I only had a 3mm pricking iron, I have some larger ones on order now.
Well done. The black looks great.
Air rifle?
Nice sling
I like how you used 2 chicago screws instead of one.
Air rifle?
Nice sling
Yes started as a HW95 and has had a few changes.
Next time I would probaly still use 2 screws, but maybe in line, rather than side by side.
Nicely done.
