pete Report post Posted November 25, 2008 got a job making a few dozen I.D. tags. I punch a hole for a split ring attachment but I want to put an eyelet in the hole. I have the little brass TLF ones that are pre-cut/scored . What should I use to tap down the brass notches. I have been bending each one down with the tip of a screwdriver! Is there a simple tool to crimp it properly? pete Quote Share this post Link to post Share on other sites
Luke Hatley Report post Posted November 25, 2008 got a job making a few dozen I.D. tags. I punch a hole for a split ring attachment but I want to put an eyelet in the hole.I have the little brass TLF ones that are pre-cut/scored . What should I use to tap down the brass notches. I have been bending each one down with the tip of a screwdriver! Is there a simple tool to crimp it properly? pete pete take a look at the Tandy Eyelet setter. you might want to look at the small Groments i like them better. Quote Share this post Link to post Share on other sites
