Skiving Heavy Belts For Buckle Bend. Hinge Spot Only Or Past That To Tip?
Really enjoying opportunities for artistic freedoms making heavy duty belts. I use two layers of 7-8 ounce Hermann Oak leather. At the buckle end my belts are of course too thick for a complete bend without trimming, so I skive them to a little over half the thickness at the tongue hinge area. It allows me to bend without cracking and helps the tab lay more flat.
Recently during final assembly I've considered though either continuing skiving at the hinge, or going further and skiving from the hinge point to the buckle end tip. I've read here about some craftspeople who taper the inner layer from the buckle hinge to the tip before laminating, leaving one layer only at that section. I could gum trag that section to smooth the surface.
Are there any downsides to skiving to the tip I'm missing?
Don
Why not just stop the inside layer at the fold? What is that second layer doing for you, other than making a bunch of bulky bulge right there?
When I do a double thickness belt I stop the second layer about a half an inch before the first chicago screw hole. This allows me to fold the outer layer back for the buckle end and it winds up the same thickness as the rest of the belt. no skiving is needed this way.
Hope that makes sense.
post-22515-0-87061700-1440166291_thumb.j
My first try at a double belt, from a few years ago. It's not the best but it shows what I am talking about. The back end of the fold lays flatter when I make then now a days.
Thanks to the both of you. What you all have shared is what I was trying to communicate. A single layer would look better than a skived then sanded transition from double to single layer I believe too. Thank you for the validation. Don.
These two pictures tell how I do the ends of my belts. They are double layer until it gets to the buckle end, . . . where I drop the bottom layer, . . . fold over the top, . . . they mate together, . . . and it is smooth on the belly.
May God bless,
Dwight
post-6728-0-88959700-1440187365_thumb.jp
post-6728-0-99090200-1440187432_thumb.jp
Dwight that's wonderful. I really like the mated radius. Don.
