Beewoman Report post Posted September 26, 2015 Hi, I bought a Singer 45k1 yesterday and having got it home I cannot remove the shuttle bobbin. The manual says to "take hold of the knob, pulling it slightly towards you in order to release the shuttle guard ring" The "knob" will pull (it seems a bit wobbly/loose) but does not release the shuttle guard ring. As it seems loose I dont want to pull it too hard - but what am I doing wrong????? Pulling my hair out here guys!!!!! Quote Share this post Link to post Share on other sites
Constabulary Report post Posted September 26, 2015 You want to remove just the bobbin not the whole shuttle, right? Put a screw driver between the shuttle housing and the small tab left of the housing then push the screw driver carefully to the left. Quote Share this post Link to post Share on other sites
dirtclod Report post Posted September 26, 2015 (edited) I see now your machine has a different type of bobbin than I was thinking about. Edited September 26, 2015 by dirtclod Quote Share this post Link to post Share on other sites
jimi Report post Posted September 26, 2015 Hi dirtclod, the shuttle guard ring moves over to the side to let you in to the shuttle, letting you open the shuttle barrel to pop the spool out. you can see this explained in the manual. http://leatherworker.net/forum/index.php?showtopic=61619&hl=%2Bsinger+%2B45k+%2Bmanual. regards jimi. Quote Share this post Link to post Share on other sites
Beewoman Report post Posted September 28, 2015 THanks for your responses It was the shuttle guard ring that wouldn't move. In the end I had to loosen the screw - seems it had been rather enthusiastically tightened. Quote Share this post Link to post Share on other sites
