venator
Multi Layer Belts
I was wondering if there are any decent tutorials on multi-layer belts. Say a suede backed by vegetan or a nice exterior leather backed in vegetan.
Anyone know of any?
Thanks folks.
Stu
Go out to Google, . . . type in youtube multi layer belts.
If it is there, . . . you'll see it.
I personally wouldn't build a belt like that, . . . but that is just me, . . .
May God bless,
Dwight
Cut strip of each type of leather, apply contact cement, bond layers together. Stitch for reinforcement. Paint edges, punch holes, attach buckle.
Granted that's a bit OVER simplified, but it does cover all the bases. :)
You might try searching for variations on "lining a belt with chrome tanned leather". I know it's been done by multiple people, and by specifying "chrome tanned" you'll remove a lot of the search results that would pop up with double layer belts (like gun belts)
When gluing layer for a belt, make sure you have them over a curved surface around the same bend as a person's waist.
as impulse said you need to glue the layers together in a curve if not the belt will be stretched on the out side and wrinkled on the inside.
