Members dfrensdorff Posted January 11, 2016 Members Report Posted January 11, 2016 (edited) Hello All.........I am in the process of making a veg tan belt.....basketweave stamping......I would like to have the first 1/4" of the edge to be black, and the middle basketweave section to stay natural....kind of a moving/blending from black to natural. I hope I am explaining this well enough..........Any thoughts on how this is done? Thanks............Don Edited January 11, 2016 by dfrensdorff Quote
Members TinkerTailor Posted January 11, 2016 Members Report Posted January 11, 2016 air brush +1 Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
electrathon Posted January 11, 2016 Report Posted January 11, 2016 (edited) This effect Edited January 11, 2016 by electrathon Quote
Members TinkerTailor Posted January 11, 2016 Members Report Posted January 11, 2016 This effect Just a heads up, I have had the dye from those printed paper towels transfer to stuff when using them with solvents. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members dfrensdorff Posted January 12, 2016 Author Members Report Posted January 12, 2016 This effect Not exactly......what I am looking to do is have black along each of the edges in about 1/4"-3/16", and then fade to natural through for the center of the belt. Quote
Members Studio-N Posted January 12, 2016 Members Report Posted January 12, 2016 Couple of ways - 1) the airbrush is still a good suggestion. 2) You can resist the area you want to keep natural by using lacquer or a clear acrylic (clear lac or super sheen). Paint it on where you want to keep natural. HOWEVER - you can't use a dye. It will burn thru. You'll have to use a stain. 3) There was a thread on here years ago about using a brush on rubber masking substance that would resist the dye and then could be rubbed off later. Best of luck. Quote "Out of my mind.....back in 5 minutes"
Members Halitech Posted January 12, 2016 Members Report Posted January 12, 2016 Only issue with using a resist or mask is you end up with a solid line instead of a faded effect. Airbrush or block dying would be the best 2 options Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members Studio-N Posted January 12, 2016 Members Report Posted January 12, 2016 you're right. I didn't really see he wanted to fade it. Airbrush is a good way to do it. And if money is not an issue the best airbrush to use is a dual action airbrush. Single action airbrushes go 100% flow when you press the trigger. A dual action gets the air flowing when you press the trigger but zero flow. You control the flow as you pull the same trigger back. Gives you a lot of control and option. You can fade a line as you go across it in any direction and back to full in the same swipe. Iwata is a good brand. Cheers! Quote "Out of my mind.....back in 5 minutes"
Members Halitech Posted January 12, 2016 Members Report Posted January 12, 2016 I have a cheap one of both. The double action is good for dye and I use the single action and adjust the pressure for spraying resolene. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
