Members dikman Posted January 24, 2016 Members Report Posted January 24, 2016 My 335 is one of the older type models, and technical information on them is rather scarce (other than what's been made available here). The meagre info I have says it can do 5 1/2 spi, but mine won't do less than 8 spi. Anyone know if there's an internal adjustment where I can get it to 5 or so? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted January 24, 2016 Members Report Posted January 24, 2016 Don´t know but I have a picture form a very old 145 parts list and maybe it can give you some hints. The adjuster mechanism should be the same Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted January 24, 2016 Members Report Posted January 24, 2016 When I look at the picture, then there is a plate #9626 - any chance that your plate has a shorter slot or small metal pieces behind it that probably cuts the movement of the adjuster knob? I remember I have seen this modification on a Dürkopp 239 machine. I removed it and viola longer stitches! BTW - alway helpful when you post pictures. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted January 24, 2016 Author Members Report Posted January 24, 2016 Thanks Constabulary, that could be quite a help as I can't see inside to get a clear picture of what's connected to where. Mine already has full travel on the adjuster (9610). I see there is an adjustment screw, #64, that might have something to do with it (if I'm lucky), but first I have to figure out exactly how it changes the stitch length. A photo - Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted January 24, 2016 Members Report Posted January 24, 2016 Your machine is a dedicated binder machine so short stitches are not too unusual. I would say maybe it is the mentioned plate - I´d probably remove it and see if the stitches become longer when you hand crank the machine w/o the plate. Also check your needle plate - maybe you will need one with a longer slot when you increase the stitch length. You know what I mean? I have two list of Pfaff 335 sub classes maybe you can compare the tag on your machine with them to find out more. 335 H3 Subclass Old C.pdf Pfaff 335 Subclass parts.pdf Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted January 24, 2016 Author Members Report Posted January 24, 2016 Makes sense about the short stitches, being originally a binder. I've already removed the binder parts and replaced the feet and needle plate/feed dog to make it a "conventional" stitcher. It works well, except for the stitch length. I'm about to go out, armed with your first photo, and start poking around in the innards! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted January 25, 2016 Author Members Report Posted January 25, 2016 Ok, referring to your first picture - the adjuster lever (9612) is already resting on part 9626 at the bottom of its travel. No plate holding it back. the screw (64) isn't an adjuster, it secures the adjuster lever to part 9606. by carefully grinding the front plate (9626) at the bottom, I managed to lower the adjuster lever just enough to give me 6 spi. Part #9633 is an eccentric that fits on the main shaft, and is held on by two screws at the back. Its position affects the spi. By loosening the screws and shifting it around I can change the spi, but I can't get any better than 6spi. I'm still trying to figure out how moving the lever changes the spi . Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Kohlrausch Posted January 26, 2016 Report Posted January 26, 2016 Hi, 4 mm (6 spi) was the original maximum stitchlength of this generation of Pfaff walking foot machines. 4,5 mm, 6 mm, 8 mm and 10 mm were different subclasses which would be designated by a letter on the brassplate like M or N. My Pfaff 145 from the same vintage with no extra letter just does 4 mm, after some careful adjustment it does 5 mm. Greets Ralf C. but I can't get any better than 6spi.I'm still trying to figure out how moving the lever changes the spi . Quote
Members dikman Posted January 26, 2016 Author Members Report Posted January 26, 2016 (edited) Thanks Ralf, I would say that there has to be an adjustment inside somewhere, I just don't see them making separate components for each machine to get the stitch length. Mine, by the way, is labelled 335-17B and underneath that is L (no idea what L means). I've just had a closer look (again) and the only adjustment that I can see anywhere is that eccentric (part #9633). I'm beginning to wonder if they do, in fact, make different size eccentrics to fit on the main shaft to give different stitch lengths. Constabulary/Ralf, what does "vollstg" (part #9636) translate as? Assembly? Edited January 26, 2016 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Kohlrausch Posted January 26, 2016 Report Posted January 26, 2016 (edited) Thanks Ralf, I would say that there has to be an adjustment inside somewhere, I just don't see them making separate components for each machine to get the stitch length. Mine, by the way, is labelled 335-17B and underneath that is L (no idea what L means). I've just had a closer look (again) and the only adjustment that I can see anywhere is that eccentric (part #9633). I'm beginning to wonder if they do, in fact, make different size eccentrics to fit on the main shaft to give different stitch lengths. Constabulary/Ralf, what does "vollstg" (part #9636) translate as? Assembly? Hi, vollstg appears to be short for vollständig meaning complete. And L, (tadaaa, tadaaa, tadaaa!) , is for Leder (Leather). B is for medium heavy stuff. The nomenclature was A, B, C, D - with A being for light material, B for medium material, B/C for medium heavy material, C for heavy material and D for ultra heavy material. Practical differences were diameter of stitchholes, diameter of machine pulley and strength of pressure foot spring. Differences in pressure foot lift would have been H1, H2 (7 mm), H3 (11 mm) and H4 (14 mm). S ( for Stoff (fabric) and L may have been the difference of soft or sharp pressure feet. To the best of my knowledge Pfaff have never openly specified what light or heavy material ment. All of that can have been swapped out or readjusted, of course. Greets Ralf C. Edited January 26, 2016 by Kohlrausch Quote
Kohlrausch Posted January 26, 2016 Report Posted January 26, 2016 (edited) I'm still trying to figure out how moving the lever changes the spi . Hi, here http://www.occaphot-ch.com/bernina-startseite/industrie-masch/ you can find a downloadable scan of the German sewingmachine mechanics book "Der Nähmaschinenfachmann". Vol 2 (Band 2) describes the old Pfaff 335, starting at page 108. It's German, but at least there is a drawing of the stitchlength mechanism. HTH Greets Ralf C. Edited January 26, 2016 by Kohlrausch Quote
Members TinkerTailor Posted January 26, 2016 Members Report Posted January 26, 2016 Those german manuals are pretty cool. In Volume 2, on pdf page 80 i found a scale diagram chart of all the needle systems, I have never seen this. A scale visual representation of needle systems could be pretty useful for finding needles for these old machines. I wish I read german.. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members Constabulary Posted January 26, 2016 Members Report Posted January 26, 2016 Learn it it will not hurt you. I had to learn English too. It´s not perfect but I survived 2 weeks in the USA. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members TinkerTailor Posted January 26, 2016 Members Report Posted January 26, 2016 I live in Vancouver Bc. I need to learn mandarin first... Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members dikman Posted January 26, 2016 Author Members Report Posted January 26, 2016 Thanks Ralf, even if I can't read the words, there's some great drawings in there. I'll have a closer look later. "Complete" makes sense, as part 9636 would then include the eccentric that fits over the main shaft and the outer race that it rotates in. I can see where slightly different sizes could then vary the max/min stitch lengths available. Which means I'm stuck with a minimum of 6 spi, but it's workable. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Kohlrausch Posted April 25, 2018 Report Posted April 25, 2018 On 26.1.2016 at 2:57 PM, Kohlrausch said: Hi, here http://www.occaphot-ch.com/bernina-startseite/industrie-masch/ you can find a downloadable scan of the German sewingmachine mechanics book "Der Nähmaschinenfachmann". Vol 2 (Band 2) describes the old Pfaff 335, starting at page 108. It's German, but at least there is a drawing of the stitchlength mechanism. HTH Greets Ralf C. Hi, Eddy occasionally reorganizes his homepage. Der Nähmaschinenfachmann now can be found at https://www.occaphot-ch.com/bernina-original-service-manuals/ Greets Ralf C. Quote
