panchoskywalker
How Can I Darken These Shoes?
Hello, I recently bought these shoes and I realize I would like them to be darken. I have a brown dye that I like a lot which I used to dye this watch strap.
How can I apply the dye I like on the shoes? Should I do something to the shoes before applying the dye?
You can but it would be easier and simpler to control if you just buy some kiwi wax in a darker brown colour. A good polish or two and they'll darken right up. If you do try to dye them make sure you clean and deglaze thoroughly as any wax polish will act as a resist.
Thanks for your answer, I think I' gonna go with the kiwi wax, but just to know how is the process of deglazing?
In order to ensure even penetration of whatever treatment you use, you must remove all wax and factory finish. There are so many processes used to finish leather, from various plastics to hard waxes, that you may need to figure out how to remove the coatings on your particular leather.
Products like this are a good starting point - http://www.amazon.com/Angelus-Leather-Prepare-Deglazer-Oz/dp/B00EU322DQ
Edited by Nuttish
