Glockanator, . . .
OK, . . . got mine fixed, . . . it would sew 20 or so stitches then somehow catch the thread, . . . next time, . . . 2 stitches.
I took out the needle, . . . then took a straight pin, . . . stuck it in the "eye", . . . and played with it until I got it to sew, . . . by moving the needle back and forth.
When the pin, . . . stuck in the eye, . . . was pointing to about 3:30 or almost 4:00, . . . it finally decided that It would sew.
I was able to completely sew my niece's belt up with it, . . . did not skip a stitch or catch even once.
May God bless,
Dwight
post-6728-0-88377400-1457838124_thumb.jp
Edited by Dwight
www.dwightsgunleather.com
Glockanator, . . .
May God bless,
Dwight
This suggests that there is a problem with the size and or duration of the loop that's formed by the ascending needle. Perhaps your check spring needs to be adjusted to get a better loop.
Posted IMHO, by Wiz
sorry dumb question 3.30 or 4.00 what do you mean??
If you look down on the top of the needle, . . . like you were standing up in front of the machine, . . . it's 3:30 or three-thirty on the clock, . . . or 4:00 or four o'clock.
It indicates where the pin would be pointing.
AND, . . . thanks Wizcrafts, . . . gives me something else to look at.
I've actually gotten a bit lax in my "maintenance" schedule here in the last few years, . . . need to just toss a dart onto the calendar and whatever day that hits, . . . got to take some stuff down, . . . PM and clean it, . . . put it back in operation. I used to be really good at doing that stuff, . . . gotten lazy in my old age, . . . kinda got to the "if it ain't broke, don't fix it" routine.
May God bless,
Dwight
Thanks for the explanation, I'll try that with mine, the skipping stitches is an on going frustration and any solution is worth a try :-)
Actually, . . . this is an old trick I learned years ago, . . . and while I've never kept a log sheet, . . . the different needles seem for some reason to like different positions. All I'm doing is making sure that when I lock it down this time, . . . it is not where it was when I loosened it up.
I had taken the needle out to check the size on it, . . . and when I put it back in, . . . it all went south, . . . seems OK for now.
I've got a pancake holster to do for an order, . . . I'll find out for sure then if all is well.
May God bless,
Dwight
