holes are already pre punched with a pricking iron, doing a saddle stitch just takes time is all, especially with all the stitching that has been done on the bag. Added up the time (not including what is left to do) and it will be 28 hours flat, next bag i may be able to cut the time down a little bit as this is the first bag of this design i have done. Wasn't to sure about how i had the holes set up but they are dead on so I am happy about that!
Oh also forgot to mention on the gusset there is no fold, no 90 degree square or even something that resembles a bent edge, so no glue is really able to be used so stiching one hole at a time and forcing the leather to bend all the way around. It is an interesting way to sew to say the least! But I kind of like this look a little more then I do with the straight look. Also there are 7 stitches per inch if anyone is interested in that. and that goes for every stitch on the bag from attactching the back flap to every last stitch
Edited by Windrider30
26 hours total of hand stitching is DONE!!! just have to do the straps and that is the easiest part! Pics are of front, side and bottom
post-54720-0-99394500-1458005949_thumb.j
post-54720-0-51059300-1458005961_thumb.j
post-54720-0-71818700-1458006000_thumb.j
Finally after 26 hours of hand stitching, 2 days of cutting, dyeing, slicking and a lot of swearing this messenger bag is FINISHED! added an adjustable shoulder strap.
Measurements
H 10 3/4 inchs
W: 12 1/4 inches
Depth 4 inches
7 SPI
back pocket is 9 1/4 inches wide 6 1/4 inches high (its a flat pocket so that is pretty much the depth as well
front pocket:
H: 5 1/2 inches
W 5 17/16 inches
Depth max 1 1/2 inches
good place to store a cell phone in the back, or the front as well as a few other odds and ends such as sunglasses in the front pocket or car keys.
post-54720-0-28796200-1458089330_thumb.j
I like the beefieness of the bag. For some reason it gives me a "steampunk" vibe. The only flaws I noticed were the color variation between the front pocket flap and the rest of the bag and the streakiness of the dye application. This is a problem I have also.
I have started thinning the dye so I can add more coats without going super dark and paying attention to my surface prep. I'm not there yet but getting better.
drnorwood thanks and hmm steampunk vibe might be a good route to go next time. The color variation is actually something that I was going for just away to make certain things stand out but once in a while that can actually be a real pain in the ass to get the look i want with the gel antiques that i use (tandy's eco flo) as well as with the streakiness i do not like a simple flat looking bag. I was thinking about going for a distressed look like with what i did with my wallet (must get pictures of it) basicly dyed it, let the dye dry then hit the wallet with sand paper, redyed, let it dry, hit again with the sand paper until i found a look i liked, took 8 coats on the wallet to get the look i was going for. But I do agree if you do not want a streaked look it can be a pain in the ass with the gells.
