Bigfoote Report post Posted March 25, 2016 I am having a little problem with my work, and don't know who to ask for help. The project is wet forming leather for a small pouch in a two part form. When I pull my forms apart there is a lot of staining on part of the leather. My forms are maple, with a coat of lacquer. I am soaking the leather in fairly hot water before I put them in the form. Then I am using some very modest heat to help dry them in the form. I will attach photos so you can see the problem. Any suggestions would be greatly appreciated, Thanks. Quote Share this post Link to post Share on other sites
Roq Report post Posted March 25, 2016 It looks like most of the staining is coming from the base. I would lightly sand the base and the mold to give the finish some tooth then refinish with 3 or more coats. Make sure all areas of the mold and base are sealed, even where they attach to each other. Quote Share this post Link to post Share on other sites
Bigfoote Report post Posted March 25, 2016 (edited) Roq, I tried the mold again with cold water this time, the hot water seems to have been the problem. No staining at all. I didn't know you could form leather without warming it up first. I am also going to give my mold a couple more coats of lacquer as you suggest Roq, thanks, Garry. Edited March 25, 2016 by Bigfoote make clearer who I was answering. Quote Share this post Link to post Share on other sites
Halitech Report post Posted March 26, 2016 I've always used cool to lukewarm water when doing my wet molding. I know boiling hot was used in armour making but cool water seems to give me more time to get things stretched out and in proper position over hot. Quote Share this post Link to post Share on other sites
Bigfoote Report post Posted March 27, 2016 Thanks Halitech, I have done a couple since with cold water, and no problem. Also the leather is not near as stiff when finished. I'm still learning appreciate the feed back. Quote Share this post Link to post Share on other sites
