Members Jess Jones Posted May 26, 2016 Members Report Posted May 26, 2016 (edited) Hi everyone! Need any advice I can get. I am making this bag for a gentleman and he wants a false buckle. I have attached photos of what I am working with. Two straps (one on each side) that have a buckle attached but a magnet underneath that is what closes the bag. The buckle is just for looks which is what he asked for. The magnet underneath magnetizes to the spiked studs. But after doing this I realized that once he holds the handle that it will open and the magnets will not be strong enough to bear the weight. What is my solution here? Open to ideas but really would rather not place any plastic hardware on this bag, if possible. Thank you for your help!!!! Edited May 26, 2016 by Jess Jones Quote "Intentionally box yourself into a corner on every project. Then find the courage within yourself to overcome it via the imagination and questions. Stay hungry. Stay curious. With time and heart, you WILL succeed." -Jess Jones
Contributing Member TwinOaks Posted May 26, 2016 Contributing Member Report Posted May 26, 2016 Without seeing the rest of the bag, it's hard to make definite suggestions, but I will start with " Change something so that the flap isn't supporting the bag" - or - "have the straps run though slot first, so you limit the direction the strap can pull" If you're just using hidden magnets, then you may need to redesign the magnetic closure to include an actual bag clasp, which IS designed to provide some support Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Jess Jones Posted May 26, 2016 Author Members Report Posted May 26, 2016 On 5/26/2016 at 3:09 AM, TwinOaks said: Without seeing the rest of the bag, it's hard to make definite suggestions, but I will start with " Change something so that the flap isn't supporting the bag" - or - "have the straps run though slot first, so you limit the direction the strap can pull" If you're just using hidden magnets, then you may need to redesign the magnetic closure to include an actual bag clasp, which IS designed to provide some support Expand Thank you! Great ideas! Quote "Intentionally box yourself into a corner on every project. Then find the courage within yourself to overcome it via the imagination and questions. Stay hungry. Stay curious. With time and heart, you WILL succeed." -Jess Jones
RockyAussie Posted May 26, 2016 Report Posted May 26, 2016 Not sure if this will help but this was my solution for something similar. You could replace the catches with a M+F magnet fitting and that may do. This tool bag I designed for a friend who is a Barrister and the design on the end is my idea of the scales of justice and the handlebars with the long road ahead. Really it was for his sunglasses etc like a glove box. Best of luck and look forward to seeing the rest of your nice work. Regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Boriqua Posted May 26, 2016 Report Posted May 26, 2016 (edited) I have done a bunch of stuff with magnets in childrens exhibits. The big problem you are facing is that you dont have enough surface at the tip of a stud for it to make for proper adhesion. It looks like you are past the point where you can replace one of the studs with something flat but if you could I would replace one of the studs with a flat square and I would use high strength earth magnets on my straps. I've held up a good deal of weight with the earth magnets Ultra-High-Pull Neodymium Magnets http://www.mcmaster.com/#standard-magnets/=12koroo Edited May 26, 2016 by Boriqua Quote
Members JMWendt Posted May 26, 2016 Members Report Posted May 26, 2016 Velcro? Hidden strap hook? You know, they make some seriously strong magnets these days, capable of holding 20 lbs on a tiny rare earth magnet. You might look into that. Quote
Members impulse Posted May 26, 2016 Members Report Posted May 26, 2016 I also would advise using Rare earth magnets, one on each matching surface. Recently I came across an ebay seller in Hong Kong which sells these with a hole in the middle that can be simply attached with a rivet. Inexpensive and with free delivery. http://www.ebay.com.au/itm/271930236395?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote
Members gigi Posted May 26, 2016 Members Report Posted May 26, 2016 (edited) On 5/26/2016 at 5:20 AM, RockyAussie said: Not sure if this will help but this was my solution for something similar. Expand Hi Brian, very nice work: love the tool bag! How do you stitch the binding cord edge? (what kind of attachment do you use for the sewing machine?). What type of cord and lining do you use? Thank you! Edited May 26, 2016 by gigi Quote Houston, we have a problem
RockyAussie Posted May 27, 2016 Report Posted May 27, 2016 Hi Gigi No special attachment. The lid is done with a french edge. The best way I find is get a long strip of supple leather and skive the start off 1/2" or so and free hand hold it against the guide both the lid and the binding and stitch it around. Finish stitching 1 or 2 inches short take out and trim of level with the first skive and then skive that piece similar to the first skive. Contact glue these 2 pieces together and proceed to finish the stitch line. Put some contact only over the stitch line and and when tacked off pull the leather out and over the edge and tap into shape a bit in corners if needed. Another line of contact in about 4mm or so from under edge, stick down when tacked off and then proceed to do the next stitch line tight against the edge of the binder. The thread is a polyamide multifilament thread called strongbond size 20. The lining is an upholstery type made for car seats I source from New South Wales Leather Co here in Australia. We use it a bit for soft tote bags and like. Hope that this helps and just ask if you need more. Regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members gigi Posted May 27, 2016 Members Report Posted May 27, 2016 (edited) Thank you Brian, very helpful info! I hope I can make a tool bag myself some day. I cannot figure out how the round ends (gussets) are attached to the rest of the bag. Edited May 27, 2016 by gigi Quote Houston, we have a problem
