RockyAussie Posted June 17, 2016 Report Posted June 17, 2016 I ground down a spare foot to enable it to get closer to the roll but if you grind back to far it will have a tendency for you to put the needle into the roll. So grind and try,grind and try. I've seen your work and know it will be no problem. Also try a plastic tapered ruler under the line when your trimming it will help. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
