Members Lissette Posted July 12, 2016 Members Report Posted July 12, 2016 Please add to this topic. Quote
Members Studio-N Posted July 12, 2016 Members Report Posted July 12, 2016 dryness is probably the largest cause. Quote "Out of my mind.....back in 5 minutes"
Mike516 Posted July 12, 2016 Report Posted July 12, 2016 I had a problem with cracking. I was using cheap leather. I upgraded my leather and wallah! problem solved. Quote
Members Studio-N Posted July 12, 2016 Members Report Posted July 12, 2016 9 minutes ago, Mike516 said: I had a problem with cracking. I was using cheap leather. I upgraded my leather and wallah! problem solved. I would expect so. cheap leather is usually dry. A good leather has a healthy dose of 'fat licquor' added during the tanning process. the result being a very flexible, supple leather. Quote "Out of my mind.....back in 5 minutes"
Mike516 Posted July 12, 2016 Report Posted July 12, 2016 1 minute ago, Studio-N said: I would expect so. cheap leather is usually dry. A good leather has a healthy dose of 'fat licquor' added during the tanning process. the result being a very flexible, supple leather. Right, but now I always bend the leather at the buckle or chain or whatever when it's still wet from the original casing no matter what. Nothing worse than finishing a belt and cracking it putting on the hardware. But the better leather is much more supple and a pleasure to work with for sure. Quote
Boriqua Posted July 13, 2016 Report Posted July 13, 2016 I havent had a problem ever when using weaver leather but I have lost HOURS of work to cracking using stuff from tandy. Had to throw out an almost completed set of saddlebags when the leather cracked on a 4 inch radius gusset. That is NOT enough of a bend to crack leather .. you would think. Im with Mike on this one .. I dont care if angels carried the leather to use for a belt on a pillow of unicorn feathers. On a belt I moisten that tight a bend each and every time. Quote
