I've done it with a foam brush and it worked fine. Just make sure that it is room temp when you do it or it will streak.
I have had very good results with a cheap, throw away camel hair brush (that I wash out with hand soap after each use) and it works super well.
The secret is twofold: a) dilute the resolene to a 50/50 solution of resolene and water AND B) apply two wet coats together, starting with the inside of the holster, then the back side, soaking into the flesh side of the leather. Once the first coat has been applied, . . . brush it until you have an almost foam like appearance that will then disappear with a bit more brushing. Continue to the smooth side of the leather pieces, . . . again soaking, working up the foam, and brushing until the foam bubbles are basically gone.
It is not as important on the flesh side, . . . but on the smooth side, . . . brush untill the bubbles are gone.
Now, . . . go back, . . . right now, . . . and do it again.
I like to hang my project up in the window, . . . let the sun's heat dry it, . . . or I hang it up about 7 feet above the furnace register, . . . it gets heat, . . . just not all at once.
I only had one problem with this method, . . . I got in a hurry on a black OWB I did for a .40 Glock, . . . and some of the bubbles were not gone, . . . when they dried, . . . it looked like water spots on a finely waxed wooden table.
Dye some scrap leather pieces, . . . and practice, . . . I think you will like it.
May God bless,
Dwight
www.dwightsgunleather.com
May God bless,
Dwight
Exactly what I was looking for - thank you!
