Gregg thanks for all your help I was able to adjust the stitch length. Up to over       1 1/2" long . I did notice that the needle has to be all the way up when you hit reverse and the stitches will fall in the same hole . Thanks again for all your help .
Thanks for reporting back,glad that worked out.
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
  • 1 year later...
This question is for Ray100.  Could you please make a copy of your manual or scan it?  I would like to get a copy and have been unable to find one.
Thank you
Steve
  • 6 months later...
On 8/16/2016 at 9:03 AM, Gregg From Keystone Sewing said:
Consew 206RB-3 and -4 are going to have the same exact adjustments for this here, see attached, hope this helps, and yes, the book is certainly confusing with this adjustment as I review.
Gregg, my machine has these two scribe marks offset by about 1/8” - I tried adjusting so they were aligned and also went the same 1/8” in the opposite direction - still no effect on stitch length.  Did I misunderstand when you stated this is the adjustment to correct stitch length in the 206RB-4?
Thanks!
Gary
Cowboy 4500, Consew 206RB-4
8 hours ago, Gregg From Keystone Sewing said:
Thanks Gregg - so this doesn’t affect stitch length - only needle-feed dog timing.
Gary
