So here I am again. I moved house (again :rolleyes:) and just before doing that I finished the repair on the 20U. The lever is installed and works (thank you again Constabulary) and both machines returned from the German specialist. He was quite amazed on the fix I managed on the 20U. Both machines running fine but for the 211 I need some more replacement parts to make it perfect. They are the bottom plates left and right of the pressure foot. One (partno:240004) is still usable but the right one (looking from the sewing direction) is badly misthreated in the past. Partno:240003 (Constabulary?). I would like to replace them both as it is quit a bit of work to remake them, although I will if necessary.
Edited by fbmini
forgot a word
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
I don´t think I have the parts you need but check with College Sewing in the UK - they have a lot of 211 and 111 parts.
https://www.college-sewing.co.uk/store/240003-SLIDE-PLATE-RIGHT-INSIDE-111W
https://www.college-sewing.co.uk/store/240004-SLIDE-PLATE-LEFT-OUTSIDE-111W
Not all parts are shown in the parts section sometimes you have to search for the parts numbers
Singer 111 and 211 have a  lot of parts in common, like the feet and slide plates
https://www.college-sewing.co.uk/singer-industrial-sewing-machine-spare-parts/
