Kohlrausch Posted September 11, 2016 Report Posted September 11, 2016 Hi, I have picked up 450 needles in little white enveleopes marked Pfaff Made in Germany 5213-01 140/22 7x3 794R DYX3 150 10 SET. R The needles are marked Singer 140/22. Just out of curiosity: Why would Pfaff have rebranded Singer-needles in system 794? I have never heard of Pfaff having sold a heavy stitcher like the Juki 441 or Singer 7. Has anybody here heard of a Pfaff heavy stitcher? Greets Ralf C. (before somebody asks: @ 15 Euros including postage I just couldn't let them pass, they fit my Adler 5 after all.) Quote
Members Constabulary Posted September 12, 2016 Members Report Posted September 12, 2016 Pfaff sold machines of other brands (like Adler 5, Class 30...) under PFAFF INDUSTRUIA. I think I somewhere have seen a Adler Class 20 branded with PFAFF INDUSTRIA and I think they also build custom machines, maybe some of them needed 794 needles. Or maybe they just wanted to fill a gap in their needle range. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members TinkerTailor Posted September 12, 2016 Members Report Posted September 12, 2016 Or perhaps pfaff contracted out and made them for singer, and they were meant to be repackaged and sold as singer certified parts or something. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Trox Posted September 14, 2016 Report Posted September 14, 2016 Pfaff cl. 27 and 28 drop feed cylinder bed with barrel shuttle. Looks to be something a bit lighter than the Adler cl. 5 (Singer 45K). I do not know what needle system they use, might have been similar to the Adler cl 5 (328) Or perhaps something in the same range of the Singer cl 17. They look a bit like the last, but has described to have a barrel shuttle. The Singer have a shuttle, but not a barrel shuttle. It if those needles fit your Adler cl. 5, they cannot be similar to the 794 system the 441 use. They are way to long for a class 5 machine. Quote Tor Workshop machines: BUSM N⁰ 6 Pearson, TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine, 8" Wilh. Pedersen hand crank splitting machine, two strap cutting machines a. m.
Kohlrausch Posted September 15, 2016 Author Report Posted September 15, 2016 Naaa, I've been messing with the machine: Footbar up, needlebar up, needleclamp down - >just works out. Wouldn't try to make a holster of 20 mm hard weg tan with a size 120 needle, but it might be interesting for big quilting projects or fiddling with large and heavy projects that are just difficult to maneuvre under the needle. My main interest are folding kayaks, and once a 50+ years old skin has become hard and stiff additional space to maneuvre to the repair spot is appreciated. Greets Ralf C. Quote
Trox Posted September 15, 2016 Report Posted September 15, 2016 What subclass are you Adler 5. If been sewing 16 mm thick leather with my old 5-27, it has a spring loaded jump foot and bottom feed. It preform pretty good on leather (it's built for leather work). You do not need that much foot pressure with this jumpfoot, it follows the material backwards and takes the pressure off the feed dog. (less marks underneath the leather compared to a regular bottom feed system). I also have a complete original saddlers attachment pack for it, with presser feets and needle plates etc.. It's a very good machine, I keep it as a backup machine it's still in new condition. I also like the old 328 needle system, it produce much less heat compared the longer 794. The needle on my 441 can be hot enough to melt thread sometimes, it need to use lubricant to cool it down on long runs. Quote Tor Workshop machines: BUSM N⁰ 6 Pearson, TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine, 8" Wilh. Pedersen hand crank splitting machine, two strap cutting machines a. m.
Thor Posted September 15, 2016 Report Posted September 15, 2016 Once I'm back home I'll go find a picture of the old Pfaff the Bailey saddlery uses. It uses such a large needle. Don't remember the model but it's definitely a Pfaff and older than I am. Quote
Trox Posted September 15, 2016 Report Posted September 15, 2016 4 minutes ago, Thor said: Once I'm back home I'll go find a picture of the old Pfaff the Bailey saddlery uses. It uses such a large needle. Don't remember the model but it's definitely a Pfaff and older than I am. You can see how the Pfaff cl. 27 and 28 looks like in Sieck.de web site. Go too category "arm machines" (English language), to compare to the one you are talking about. Quote Tor Workshop machines: BUSM N⁰ 6 Pearson, TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine, 8" Wilh. Pedersen hand crank splitting machine, two strap cutting machines a. m.
Trox Posted September 15, 2016 Report Posted September 15, 2016 17 minutes ago, Thor said: Once I'm back home I'll go find a picture of the old Pfaff the Bailey saddlery uses. It uses such a large needle. Don't remember the model but it's definitely a Pfaff and older than I am. I looked true is FB site and saw four machines in his workshop. a Pearson harness stitcher (or simmilar), a Adler 205-64, a Tipperman Boss and a old Singer 29K. No picts of the Pfaff, I look forwards to see that machine. Tor Quote Tor Workshop machines: BUSM N⁰ 6 Pearson, TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine, 8" Wilh. Pedersen hand crank splitting machine, two strap cutting machines a. m.
Thor Posted September 15, 2016 Report Posted September 15, 2016 2 hours ago, Trox said: I looked true is FB site and saw four machines in his workshop. a Pearson harness stitcher (or simmilar), a Adler 205-64, a Tipperman Boss and a old Singer 29K. No picts of the Pfaff, I look forwards to see that machine. Tor Don't know where you get this Pearson from, but you're maybe right and I have no clue what machine I was working on. I doubt Todd would use the patcher in his shop. Instead of just looking at pjctures, reading might help at times. He's selling 3 Singer patchers. BTW this is not even half of his shop you see in the pictures. Currently I'm in Scotland and will look up my pictures next week. Quote
