bikermutt07 Posted September 19, 2016 Report Posted September 19, 2016 Somebody had mentioned I needed a skiver. Well, for what you have to spend on one you don't get much cutting surface. According to Mr. Johnson any pull through skiver is good for three inches of width. Whether it's a four inch, 6 inch, or even an eight inch. That's great for a belt, but not much good for even a wallet. The readily available hand cranks I have seen are about $1400.00 new for a six inch. That could work for many more things than a belt or a wallet, but still not big enough for say a holster. And $1400.00 is way way out of my price range. I'm getting there (to my point). Today at work a guy was changing out a blade on a flooring cutter. I didn't put a tape measure on it but I figure it's a 12 inch blade. It had a single edge sharpened of about 60 degrees. Hmmmmmm. Ok, here comes the idiocy part. Do you think a hand crank laundry wringer could be set up like a skiver. I would have to "machine" a bracket for the blade. But I think this could possibly work. I can get a quality wringer for $150.00. I can salvage the old blade and VOILA!! Well, anybody ever march to this drummer? Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
RockyAussie Posted September 19, 2016 Report Posted September 19, 2016 Well If you got that amount of time on yr hands..... why not get a bandsaw and turn it on its side, nock the teeth off and sharpen it, pully up the hand crank on the wringer. Remember to leave room for a strap folder to feed through the wringer as well. Ha whala. Honest I would do it sept I already got 2 bandknife splitters. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
bikermutt07 Posted September 19, 2016 Author Report Posted September 19, 2016 17 minutes ago, RockyAussie said: Well If you got that amount of time on yr hands..... why not get a bandsaw and turn it on its side, nock the teeth off and sharpen it, pully up the hand crank on the wringer. Remember to leave room for a strap folder to feed through the wringer as well. Ha whala. Honest I would do it sept I already got 2 bandknife splitters. Well, I've seen your small Gerry-rigged skiving sander, so nanner nanner manner. Which actually works quite well. Heck, it don't hurt to try. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
RockyAussie Posted September 20, 2016 Report Posted September 20, 2016 Nuther idea... Get that blade and put in some elongated holes about 3/8" to 1/2" long like in an electric knife and set one end up to attach to an electric jigsaw. I think that could be easier and prolong the need for sharpening a lot but would still have to be taken out for sharpening occasionally. Should we patent this? Ha bugger everyone knows now Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
bikermutt07 Posted September 20, 2016 Author Report Posted September 20, 2016 See, now you're just pokin fun. Ha! Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
RockyAussie Posted September 20, 2016 Report Posted September 20, 2016 Honest I wasn............well...... read your subject heading!!!!!!What about a nice level vacume table to hold the leather all down flat and an electric wood planer suspended on an adjustable drop down ...........No i reckon your idea should work OK Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
bikermutt07 Posted September 20, 2016 Author Report Posted September 20, 2016 Wait...... I've got a Bosch planer. Can I make a vacuum box out of Tupperware and a shop vac? Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
bikermutt07 Posted September 20, 2016 Author Report Posted September 20, 2016 (edited) While I have your attention..... Not having any close up experience with a skiver, is it just a blade and rollers with some adjustment? I think I can probably come up with a solution for adjusting it up and down for thickness. If the rollers will push it is there any kind of offeed contraption I should consider? I downloaded Bruce Johnson's instructions on adjusting one, and well other than tight tolerances, I don't see too much in them. Edited September 20, 2016 by bikermutt07 Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
RockyAussie Posted September 20, 2016 Report Posted September 20, 2016 As you described they are pretty much just that. I have had in the past a few types and if all you really want to do is skive mellow veg they are not to bad, but if you ever want to split/skive any soft or thinish stuff your in trouble and taking out the blade to sharpen it sure pysoff pretty quick. Wasting your money on a lot off this stuff I believe and I wish I had gotten at least a Fortuna skiver right from the start and saved a lot of money and agro. Make sure that it has an aspirator (suction device for extracting the waste). 2nd hand generally about 1k or less but new not to bad if you shop around. If that's all to much you wont go too wrong following something along my Multisander adaptation.I hope to do up a new updated version of same this Christmas, and I will post some plans. Tom posted an interesting one last week but the time to do is something to consider if you are paying yourself anything worthwhile. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
bikermutt07 Posted September 20, 2016 Author Report Posted September 20, 2016 Thanks. A grand is pretty rich for a hobby. I think I should have said splitter instead of skiver. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
