Boriqua Posted October 19, 2016 Report Posted October 19, 2016 Billy Hell asked about a double mag pouch pattern in another thread so I figured I would post it here for anyone interested and not crap in Jeff's wonderful thread. This is really easy to make and you can easily convert it to a single. The back is one piece and I usually go a little heavier leather on the back than the front. Dye the back piece Line up the lines and come down about 1/2 inch and sew or rivet the straps to the back. Sew down center line Go 1/4 out to each side of center line and sew Pull in ends and match them up to back. Glue .. if you are careful here it will save you a bunch of sanding later. You can dampen the center of what will become each pouch to make the ends line up easier. Sew down the two outsides Now take a sponge and wet only the front piece from the top all the way out to the ends and just around the bottom. its not necessary to wet the strap at the back and you shouldnt wet the back piece at all. Because you didnt wet the back and the back piece is slightly heavier than the front but gave a fair wetting to the front and bottom when you force your mag in it will form nicely but leave a mostly flat back. You can do a little extra boning to the front if you like .. I just form with my fingers but I think I would crisp it up some with some boning when I do this one again. Dye what hasnt been dyed and seal Here is the file. http://boriqualeather.com/stuff/Double Mag Pouch.jpg Quote
Members Billy Hell Posted October 19, 2016 Members Report Posted October 19, 2016 Great! It's on the work list to make! Quote
Boriqua Posted October 19, 2016 Author Report Posted October 19, 2016 Found a more recent version... Well my freaking cat decided to play in my enormous pile of patterns so I guess she found it!! anyway the only change was I curved the cuts where it met the strap and it did look a little cleaner on the finished project and was easier to burnish. See red detail Quote
Contributing Member JLSleather Posted October 20, 2016 Contributing Member Report Posted October 20, 2016 Sweet Clean, simple, quick, effective... nice. But I don't see the one like that for the Bersa Thunder .380 the guy asked for yesterday and he really wants it! Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Billy Hell Posted November 20, 2016 Members Report Posted November 20, 2016 Boriqua Sorry to task you again but could you throw some measurements on there so I know I'm printing out the right dimensions? Going to make a mag pouch to go with the this Tome Threepersons holster... Quote
Boriqua Posted November 21, 2016 Author Report Posted November 21, 2016 Here ya go .. I threw some measurements around so you can check it against your print. The File link I posted above Should print full size but I know that can get weird sometimes depending on the program. I can try and scan it to PDF if that works better but with the measurements its easy enough to replicate. Quote
Members Billy Hell Posted November 22, 2016 Members Report Posted November 22, 2016 I was pretty excited to get this done. I knew my measurements were slightly off BUT when I got to the last two sides I realized I left myself no way to stitch them on - DOH! Quote
Contributing Member JLSleather Posted November 22, 2016 Contributing Member Report Posted November 22, 2016 Sweet... now there's two of us who occasionally make a mistake Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Billy Hell Posted November 23, 2016 Members Report Posted November 23, 2016 I pulled the short back off and cut another one. Looks great with my Tom Threepersons holster... Quote
Boriqua Posted November 23, 2016 Author Report Posted November 23, 2016 The set came out sweet! Quote
Members babbadam Posted April 14, 2018 Members Report Posted April 14, 2018 Is the leather strap size that folds and makes the bottom and belt loop relative to the magazine size? Quote
Boriqua Posted April 14, 2018 Author Report Posted April 14, 2018 18 hours ago, babbadam said: Is the leather strap size that folds and makes the bottom and belt loop relative to the magazine size? Only in that the belt loops need to be inside your mag pouch sew lines. How much inside is up to you. I like chunky straps so I go as wide as I can but you will be attaching the strap to the back piece first then sewing your mag pouch closed on either end and in the middle. To wide on the straps and you wont have a way to do that. They have to be slightly narrower than you proposed stitch lines. Quote
Members babbadam Posted April 15, 2018 Members Report Posted April 15, 2018 Thank you very much. This is my first one. Quote
