Members Rabble Posted November 2, 2016 Members Report Posted November 2, 2016 I'm just getting started and trying to put tools together that will help me. I have an old Dremel Tool, model # 380 66-3, looks to be variable speed from 5,000 rpm to 25,000. Can't find an owners manual on their site, was hoping to see what speed would be good for leather, I'm thinking this unit might be too fast. Is its lowest setting too fast? And if so, would anyone know if there is a way to slow it down to a more appropriate speed? Thanks, George Quote
Members rejerome Posted November 2, 2016 Members Report Posted November 2, 2016 Not sure what you're going to do with your Dremel, but I use a newer variable speed model that has load sensing (maintains speed under load). I use it with sanding drums to even up edges and I also use it with various attachments for edge slicking. It also works great on the inside of holster belt slots For me, running at 10k-12k RPM seems to work best. Any faster and it will quickly burn edges. Slower is just, well, slower. When burnishing be sure to keep the edges plenty wet. When slicking edges on items like belts I just use a QuikGrip clamp and clamp it to the bench top and use it as a stationary bench top tool. I've made some of my own special shaped slicking tools for it. You can purchase arbors for them but I have found that a large sized pop rivet is just about the right size. The rivet end goes into the wood of the slicker and the nail shank goes into the Dremel collet. I also highly recommend a keyless chuck which you can purchase for less than $10. That way you don't have to keep track of that tiny collet wrench. I've also made a leather drum for it and it works great to quickly strop edge tools running at a slower speed. Just experiment on scrap and you'll quickly learn what speeds work best for you. I've read where you can control the speed using those widely available foot pedal switches, assuming you're Dremel is compatible. I have NOT tried using one. Just Google the phrase "dremel foot pedal speed control". Quote
Members Halitech Posted November 2, 2016 Members Report Posted November 2, 2016 I have a power fist rotary tool will speeds from 10k to 35k RPM. I usually run mine at the 2 setting for sanding. I'm waiting on a friend to make a burnisher for me so not sure on the speed required for that. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
bikermutt07 Posted November 2, 2016 Report Posted November 2, 2016 Just a plug. Pro edge burnishers makes burnishers for dremels. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members Halitech Posted November 2, 2016 Members Report Posted November 2, 2016 Bikermutt, I know they do but when a friend can make them for $15.00CDN, doesn't make much sense to pay $35US plus shipping :D Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members Rabble Posted November 2, 2016 Author Members Report Posted November 2, 2016 Thanks for the quick responses. That's exactly what I was hoping to be able to do with it. Sounds like I'm in good shape speed wise. What grit of sanding drums would you recommend? I'll take a look around for a burnisher I can use with it. I'm only just getting started but will be doing a Slim Jim tooled holster for my first project. I'm planning on being a regular on these boards. Quote
Members Halitech Posted November 2, 2016 Members Report Posted November 2, 2016 I usually keep a 120grit on mine and then use emery boards (yes, the ones women use on their nails) to finish with Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members rejerome Posted November 2, 2016 Members Report Posted November 2, 2016 For me, 80 to 120 grit works well. The 120 might load up a little faster....just depends on the leather. The pre-made slickers are nice but pricey for what you're getting. It's pretty easy to make your own slickers. It's easiest to start with a hardwood dowel that's close to the diameter you want. Cut it to the approximate length, drill a hole in one end, expoxy in an arbor or a large pop rivet. Chuck it up in your Dremel and clamp the tool down to a table top. Turn it on and start sanding the wood to the shape you want. If you have any vibration you may need to have a stationary "tool rest" of some sort so you can true up the wood to make it concentric with the arbor. Either that or the arbor is not straight. If that's the case you can usually rotate it by hand and figure out what you need to do to bend the arbor to straighten it visually. Even the "store bought" slickers may vibrate. Usually its a bent arbor. Quote
Members Rabble Posted November 2, 2016 Author Members Report Posted November 2, 2016 Thanks Halitech, I'll get some 120 grit on order, be a while til I'm on that part of the project. Did a search and Amazon came back with some from Pro Edge that look real nice, but also a pair from Co-Link that look pretty good and are a lot less. Anyone have experience with them? Reviews seem pretty good overall. Quote
Members rejerome Posted November 2, 2016 Members Report Posted November 2, 2016 Rabble, Since you're looking at Amazon, get something like this: https://www.amazon.com/Jumbo-51pc-Drum-Sanding-Kit/dp/B007FER2IW/ref=sr_1_4?ie=UTF8&qid=1478094741&sr=8-4&keywords=dremel+sanding+drum Those smaller dia drums are pretty handy! Quote
