Unisawyer
Asbestos Friction Plate?
Can someone help me to identify the friction plate material using the image attached? Perhaps it is a known configuration....
From left to right;  pulley (belt removed), friction plate material, friction plate, motor
The machine works very well. If folks know this to be an asbestos material, I will consider changing out the drive system.
Thanks.
It's cork,that is glued in.
Edited by CowboyBob
Not sure but I´ts possible. On external clutch systems like this I have seen leather as well as some very hard dense stuff same as used in some clutch motors. I know some clutch motor had asbestos fibers in their clutch plates.
I think LW Member EVO160 once replaced a clutch plate on a similar system like yours with some hard sole leather if i remember correctly.
Thanks CowboyBob. It looked similar to cork under magnification. You have put my mind at ease. :)
