I'm very new to leatherwork but I've always wanted to try it out so forgive me if this is a dumb question. I want to make some lined leather belts for christmas gifts and I was wondering if using 2 layers of garment leather and hand stitching them would look good and be durable? I'm kind of aiming for an hermes mens belt look with black leather on one side and brown leather on the other
I use 8-9oz vegtan for the outside and 3-4oz vegtan for the inside rough sides together.  After glue and tooling operations I apply dye, stitch, and finish.
Do you have to skive any of the leather that you use or can you buy it in those weights from tandy or weaver? I don't want the belt to be too thick either, are the belts that you make really thick? Would 2 strips of 3-4oz garment leather be good for a belt? Sorry for all of the questions, I'm very new to this.
Unless the wearer is fit and trim and does not cinch the belt tight, the thin stuff works.
I also use 8-9 ounce for the outer and 3/4 or 5/6 for the liner. Besides I don't think my Cobra would sew 6 ounce leather :)
take 2 pieces of garment leather, hold them together and pull. If you can live with the 3" of stretch in a belt, it will do great. If not, get some 6oz (minimum) veg tanned leather and line it with the garment. Make sure you glue it and then stitch it well (by hand, not on your home sewing machine)
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
  • 2 weeks later...
If you like you can take two layers of thin leather and hand stitch them together, but sandwich between them a material that is flexible but won't allow stretch.  One example would be 1"  nylon straps, such as used for backpacks, buried in the adhesive.
I'll save you some fuss and say to punch out oversized belt holes in the nylon ahead of time.  'oversized' because lining up the two thin straps can be a challenge and because you don't want nylon fibers peeking out.
It could also be a piece of canvas, etc.  This has been done for ages, and still is in many commercial pre-made straps.
