Members bushlover Posted December 22, 2016 Members Report Posted December 22, 2016 Hello friends ! ! I'm having a big problem today so I hope and know that some people around here will help me I want to make a sheath for this folding saw....but I'm having problems due to the big buttom on the "snipe" of that saw,I've designed a sheath but that thing against the fold of the sheath seems like it wont work I would be greatfull for some help!! Cheers and Happy Christmas! Quote
RockyAussie Posted December 22, 2016 Report Posted December 22, 2016 I think you may need to make a wooden block allowing a straight relief a bit like you would on a holster for the sights I guess. Might need a better saw though. Regards Brian Quote
Members bushlover Posted December 22, 2016 Author Members Report Posted December 22, 2016 Hey buddy!! thank you! and the saq is not mine is for a friend idk of I understood what you mean... What about if the saw fit with the balde against the fold like this...do you guys think it will work? Thank you! Quote
Members Halitech Posted December 22, 2016 Members Report Posted December 22, 2016 Check the info here http://beebeknives.com/html/make_a_sheath_tutorial.html I use this but instead of just placing the knife beside the line, I actually place the edge right on the line then roll the blade over to 1 side, like the suggest when making a gun holster. Another option, instead of having it all encased like a knife blade, make a cup to hold the bottom and use a strap to hold it in place at the top Quote
RockyAussie Posted December 22, 2016 Report Posted December 22, 2016 11 hours ago, bushlover said: Hey buddy!! thank you! and the saq is not mine is for a friend idk of I understood what you mean... What about if the saw fit with the balde against the fold like this...do you guys think it will work? Thank you! Yes that should work but make sure to use a thick welt along the stitch side and or at least block and case so as to allow the saw easy access in and out . Have fun and a Merry Christmas. Quote
