Members hwhleather Posted March 3, 2017 Members Report Posted March 3, 2017 I want to make some strops and I am wondering what the best leather to use is. Would Hermann oak 8/9 oz veg tan work? I have a lot of that on hand. Quote
electrathon Posted March 3, 2017 Report Posted March 3, 2017 Yes, it will work just fine. Horse is better. Thinner is better. Quote
Members keplerts Posted March 3, 2017 Members Report Posted March 3, 2017 Could you explain why thinner is better for a strop? Thanks, Tom Quote
Members KittenThrasher Posted March 3, 2017 Members Report Posted March 3, 2017 I glue the leather onto a piece of scrap wood to make a strop, thinner leather doesn't 'give' so much as thicker leather when pulling a blade along it, my strops usually last a few months then go in the bin and make a new one. Just in case you're interested,,,, I use two strops, one coated in fine grade automotive valve grinding paste and the other coated in 'TCut' which is an automotive paint restoring or polishing compound - my favourite for all-day-everyday use is the valve grinding paste but when I'm looking for a truly nasty edge for skiving thin soft stuff I give the blade a go on the TCut as well. Both of these products are a lot cheaper (and in my opinion better) than proprietary compounds. Quote
Members Jack142 Posted March 3, 2017 Members Report Posted March 3, 2017 here is a pic of 2 strops I made and use. I put white of green rouge on them. I really don't see a difference in them. one strop has a rubber backing ( mouse pad ) This is to strop my knives with a convex edge. the other I glued right on the wood. I used a softer leather, from what I have read you want a little "give" in the leather so it curves a bit on the edge. You don't want the leather to strop over the edge or it will dull it. Now the key is keeping soft pressure, ( I have read about the same pressure and you use when you shave ) and keeping the correct angle. which is pretty narrow.... Of course, I built these for my knives, and for touch up they work really well. I can shave with most of my knives. PS.... this is a custom Stek knife I purchase a couple of years ago Quote
Members gmace99 Posted March 3, 2017 Members Report Posted March 3, 2017 I use veg tan on both sides of my strop. On one side I put veg tan on it then ruff it up a bit. On the other side I put veg tan then spread tallow fat all over the leather then put carborundum powder on it I think I have had this strop for 30 years and changed the leather 3 or 4 times . I add more tallow and powder every few years. I was a professional English style saddle maker making 5 0r 6 saddles a week. My strop was well used in these years. In my video you can see my strop. Quote
