Members BOOMSTICKHolsters Posted January 29, 2008 Members Report Posted January 29, 2008 I want to build some edge burnishers like the kind in John Bianchi's videos to save some time. Does anyone have a source for thick sheets of 100% wool felt like what is used in saddle lining or blankets? I haven't had much luck with an internet search, as everyone I've found either sells very thin sheets or only sells in very large quantities. I would really appreciate any help you guys could give me. I would be happy to purchase some directly from someone on here as well, if any is avilable.Thanks, Jeff Quote
Members gary Posted January 29, 2008 Members Report Posted January 29, 2008 You might want to try a medical supplies place. They do some fairly thick felt (called orthopaedic felt in the UK) that I've seen in 1/8" to 1" thicknesses. It may suit your purpose. Gary Quote
Members skip Posted January 29, 2008 Members Report Posted January 29, 2008 just for grins a giggles you could go down to the local tack and feed store and buy a one inch felt pad from them and cut the wheels yourself, Not sure how much your talking about but the felt pads usually come in 30 Inch by 34 inch and you should be able to cut a couple of discs out of one pad to fulfill your needs. hope I am not too out of line. good luck Quote
Members tonyc1 Posted January 29, 2008 Members Report Posted January 29, 2008 You could try engineering supply businesses, as it is known as "Engineering Felt" out here and I always obtain mine there. Quote
Moderator Art Posted January 29, 2008 Moderator Report Posted January 29, 2008 Hi Jeff, Most of the "felt" out there is polyester, not much good for higher heat apps. The stuff from Weaver is poly so there is probably a lot of it out there in the "horsey" world. The stuff from Aetna is real wool felt like you want. F-1 felt will be 95% wool (I had to cut this with a band saw if you want that density), and there are some grades called ultra density that are as hard as wood (you don't want these). F-3 will be about 85% wool and may still be what you need (I could cut this with a round punch, but I have a BIG maul 96oz). You can call Aetna Felt for more application info. 800-526-4451 is the last # I have for them, you will have to call to order. They have a Thomas Register Website at: http://aetnafelt.thomasnet.com/viewitems/f...?&forward=1 Not much help so call. Art I want to build some edge burnishers like the kind in John Bianchi's videos to save some time. Does anyone have a source for thick sheets of 100% wool felt like what is used in saddle lining or blankets? I haven't had much luck with an internet search, as everyone I've found either sells very thin sheets or only sells in very large quantities. I would really appreciate any help you guys could give me. I would be happy to purchase some directly from someone on here as well, if any is avilable.Thanks,Jeff Quote For heaven's sakes pilgrim, make yourself a strop!
Moderator bruce johnson Posted January 29, 2008 Moderator Report Posted January 29, 2008 I tried this with some 100% felt a few years ago. Your mileage will vary, but I built up enough static electricity the first time to light up Las Vegas. Being a slow learner, I did it again to see if it was repeatable. It was. If it matters, I have rubber mats on the floor. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Billy P Posted January 29, 2008 Report Posted January 29, 2008 Hey all you saddlemaker types out there, does anyone of ya'll know where a person might could get some small pieces of felt. I need something that is fairly soft. If I can find some I want to cut them into about 1"x1" squares and make me some of the old daubers like Tandy and Zack White used to sell. They were great for dyeing edges, a lot less slop over the edges plus good for a few other things too. For what I want them for it would not make sense to try and buy a sheet. Again if anyone knows a source for the wool felt daubers I would appreciate it if you'd share it with me. Many Many thanks Billy P Quote Billy P SideLine Leather Co. Leatherworker.net/Forum
Members bcurrier Posted January 30, 2008 Members Report Posted January 30, 2008 I called Aetna felt a while ago - their all-wool, medium and high-density felts are very expensive. (Not to suggest that the pricing is so much Aetna as it is the cost of such felt itself.) As I recall, something in the medium density range, 1/2" thick was well over $100 for a sheet perhaps a couple feet square. Bill Quote
Moderator Art Posted January 30, 2008 Moderator Report Posted January 30, 2008 Hi Bill, All wool felt is not cheap, the ultra density stuff they order from who knows where, but f-1 and lower felts are roll goods that they sell by the yard. If you go to Brownell's or one of the auto finishing sites you can buy felt polishing wheels, I think a six by 1" medium wheel costs around $36. So it sounds like the price from Aetna was much better. BTW, John is now using leather wheels to do edges, my felt ones haven't worn out yet (they seem to be getting better) so I haven't tried them yet. You build them like the felt wheels except from veg tan. Art I called Aetna felt a while ago - their all-wool, medium and high-density felts are very expensive. (Not to suggest that the pricing is so much Aetna as it is the cost of such felt itself.) As I recall, something in the medium density range, 1/2" thick was well over $100 for a sheet perhaps a couple feet square.Bill Quote For heaven's sakes pilgrim, make yourself a strop!
Members BOOMSTICKHolsters Posted January 30, 2008 Author Members Report Posted January 30, 2008 Thanks, everybody, for the suggestions. I appreciate all the help. One of the generous posters on here has come to my rescue. Quote
Contributing Member barra Posted January 30, 2008 Contributing Member Report Posted January 30, 2008 Yes wool felt is as expensive as poison. You can also make your own burnishing disk by getting hold of some scrap canvas or denim and sewing together enough disks to obtain the thickness you want. Nothing fancy, big stiches will do fine. It is a chance for those old wranglers to keep on giving. Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
Ambassador Don101 Posted January 31, 2008 Ambassador Report Posted January 31, 2008 Have you tried ebay Item number: 200195502565 im not sure if thats what you want, Don Quote
esantoro Posted March 2, 2008 Report Posted March 2, 2008 Hi Bill,All wool felt is not cheap, the ultra density stuff they order from who knows where, but f-1 and lower felts are roll goods that they sell by the yard. If you go to Brownell's or one of the auto finishing sites you can buy felt polishing wheels, I think a six by 1" medium wheel costs around $36. So it sounds like the price from Aetna was much better. BTW, John is now using leather wheels to do edges, my felt ones haven't worn out yet (they seem to be getting better) so I haven't tried them yet. You build them like the felt wheels except from veg tan. Art Art, Will any felt at a fabric store be sufficient for dying edges. I imagine all I must do is cut the felt the width of the edge I'm dying. Put the felt in a clothespin and go to it. Is this about right? ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Contributing Member barra Posted March 2, 2008 Contributing Member Report Posted March 2, 2008 (edited) A passable dauber can be had by substituting the thick engineering felt with thick carpet underlay (free offcuts from the carpet store). Cut the long straight section out of a wire coat hanger. Spear it through the thickness of the underlay, bend over the wire and squash it in a vice. To fashion a handle you can just bend over the other end to give yourself something to grip or semi sharpen the end and twist on a cork. Barra Edited March 2, 2008 by barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
