Moderator Johanna Posted July 14, 2006 Moderator Report Posted July 14, 2006 Well, Do you like the new mocha skin for the board, or do you prefer the old Luna Blue? Your opinion matters. Johanna Quote
pepin1948 Posted July 14, 2006 Report Posted July 14, 2006 The brown is a warmer color, but it sure was a surprise! I like it better, though it kinda clashes with the coach and team pic up top...I'm fussy that way Quote
Members joet Posted July 14, 2006 Members Report Posted July 14, 2006 When I first opened the site I thought I was in the wrong place. Then I saw the stage coach at the top and figured you did a color change. I like it. Is there any way for a viewer to change the color on their own? I have seen that option on other forums. This site gets better every day. Quote
Moderator Johanna Posted July 15, 2006 Author Moderator Report Posted July 15, 2006 Joe, thank you for the encouraging words. I want to make this board suit the people who want to use it. If you are logged in, and you look at the bottom left of the main page, you will see an RSS button. Right next to that is the drop down menu option to change skins. The only two I have are the original blue and the new mocha, but I can add others, if someone has a suggestion. I did get some mail about smileys, so I added some. If you want to see all 35, click on "more" as you are composing a reply, and a new window will open up, displaying all. If you want to set the full smiley menu to reopen at a certain size, hold the control key down as you X out. Right now it is set to open small by default, so that you adjust the size to your convenience. If there is a smiley you want to see, or you have a favorite you want on your menu, I can add it. Johanna Quote
Members Tom Katzke Posted July 21, 2006 Members Report Posted July 21, 2006 Yep found the way to change it. I like the Blue better. I guess when you live someplace that is Brown most of the year a chearfull color like blue is nicer to look at. As for new colors how about seasonal colors? Tom Katzke Central Oregon Joe, thank you for the encouraging words. I want to make this board suit the people who want to use it. If you are logged in, and you look at the bottom left of the main page, you will see an RSS button. Right next to that is the drop down menu option to change skins. The only two I have are the original blue and the new mocha, but I can add others, if someone has a suggestion. I did get some mail about smileys, so I added some. If you want to see all 35, click on "more" as you are composing a reply, and a new window will open up, displaying all. If you want to set the full smiley menu to reopen at a certain size, hold the control key down as you X out. Right now it is set to open small by default, so that you adjust the size to your convenience. If there is a smiley you want to see, or you have a favorite you want on your menu, I can add it. Johanna Quote
