I've posted on other parts of the forum but haven't had any ideas come my way. So I thought I might try this section too. I'm trying to figure out the best way to line a bag that is this shape. I don't know if a turned lining would work, or if a drop in lining would be better? I'm worried the shape won't lend well to either of these and I may have to bind the edge a different way. Here is the front panel. Thanks!
Need more details.  Like is it going to be stitched from the outside, or is it a turned bag?  I assume a single gusset?  Are you wanting pockets in the lining?
I'm hand stitching so it will be stitched from the outside only along the top of the bag. I'm going to try a single gusset but it may be a 3 piece gusset. Im going to welt the bag as well and turn it. My concern is that I will get wrinkles at the top in the lining because of the curve of the bag. Or that the curve won't lend itself  u to being turned or bound. The edges I want bound, So I would do a turned lining if I could get away with it. But I could also do a drop in with bound edges too. I may add a few pockets too.
