Members jasonmccluer Posted July 13, 2017 Members Report Posted July 13, 2017 Recently I have been interested in keeping close to the natural color of veg tanned leather for my belts. Not something I have done before. I find after a few test belts spread out among friends and family that simply giving them a light coat of NF is not sufficient. The test belts crease quickly at the buckle, mar easily, and conform too soon to the wearer's shape. What I want to achieve is the color of slightly aged undyed veg tanned. I like the color after a light oil. I also need a mellow (low gloss) top coat or process to protect the leather and not let it darken too much too soon. I know that time and use will darken it naturally. Finally, I am wondering if there is a top finish that will give the leather a little extra strength to keep it from losing it's shape too quickly. I am using a 10 oz Hermann oak premium veg tanned bend from Springfield Leather. I like the leather but I wonder if I should go with a heavier weight or a different cut from the hide. I should also mention that I am not tooling the leather at all. I know there is probably a bunch of ways to go about it so everyone's expertise is much much appreciated. Quote
Members byggyns Posted July 13, 2017 Members Report Posted July 13, 2017 There are several options. You could go with coats of mop & glow or Resolene, which are acrylic coatings. Or, you could go with a heavy wax/oil treatment like a dubbin or carnauba creme. Some people make their own surface treatment with neatsfoot oil, beeswax, and other waxes/oils. Any of the oil treatments will darken the leather, so you'll want to try it out on scraps before using on a finished project. Quote
Members jasonmccluer Posted July 13, 2017 Author Members Report Posted July 13, 2017 1 hour ago, byggyns said: There are several options. You could go with coats of mop & glow or Resolene, which are acrylic coatings. Or, you could go with a heavy wax/oil treatment like a dubbin or carnauba creme. Some people make their own surface treatment with neatsfoot oil, beeswax, and other waxes/oils. Any of the oil treatments will darken the leather, so you'll want to try it out on scraps before using on a finished project. I have used carnauba creme mostly in the past on dyed projects. I am interested in making my own mix. I will have to explore that option. Quote
Moderator immiketoo Posted July 13, 2017 Moderator Report Posted July 13, 2017 Bee Natural RTC will give you the effect you want, but you may want to suntan your leather a bit before sealing. Quote Learnleather.com
Members Halitech Posted July 13, 2017 Members Report Posted July 13, 2017 the reason your belts aren't being protected is because NF oil is NOT a protectant. It's to put oil back into leather that has been dyed or wet molded and has lost moisture. Nigel (I think it was him) did a test on multiple finishes, both for water resistance and color change (if I remember right) and resolene was the best option of the products he tested. Resolene also has the benefit of blocking most UVA/UVB rays so it prevents the most effects of being in natural light. Most finishes won't protect the shape, stitching the edges will help some though. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members byggyns Posted July 14, 2017 Members Report Posted July 14, 2017 I have tried a mix of NF oil and beeswax, and I like it. I started out with a 1:1 mix, but I like a little more oil to make application easier. I have heard of some people adding carnauba wax to increase hardness & shine in the final coat. For heavy moisture exposure, I'd probably use resolene. I have used resolene on a 2 layer stitched gun belt, and haven't had any cracking, flaking, or obvious failure of the finish. Quote
