9 hours ago, KeithHideWorks said:
Do you mind explaining why the inline foot would cause you to lose throat?  Looking at running that with a 4500 and not sure I understand.
Thanks,
I think Wiz was referring to the Holster and Stirrup plates.  They have a raised surface for fitting thicker leather under the foot, but because they are raised you loose some clearance under the foot.  You can see how they are shaped in the picture.  The distance between the throat and the needle will be about the same.  I suspect you only use these plates on smaller thick projects that need the lift.  I assume you would use the standard plate most of the time.
One day I hope to learn how to sew.....
Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Thanks,
The inline feet are so constructed that the inside foot sticks up about 1/4 to 5/16 inch above its bottom. Whatever the amount, it is that much less that you have left for the needle to work with before the bottom of the needle bar makes contact with the top of the inside inline foot. It's not so bad if you're using the standard throat plate that comes with the machines. But, if you need to use one of the raised throat plates (to get around stirrups or next to hardware or leather that protrudes down on the left side), you will lose their height above the base plane (feed dog or standard slotted plate) height in addition to the loss from the oddly shaped inside inline alternating foot.
Posted IMHO, by Wiz
On 8/2/2017 at 8:24 PM, Yetibelle said:
l was sooooooo close to talking myself into a 4500, that I just talked myself out of it.  Darn...... I'm sure other must have struggled with this question so I'm looking for how you may have worked this out.  I technically own a few machines, but I have never had a NEW machine and now I'm ready and just can't narrow it down.  I want to run the heavy thread but in reality I don't see myself sewing thicker than 1/2 inch on most projects.  I like the idea of the longer arm but Is it worth the extra $700 for 415 and extra arm space?  Why can't the 3200 run the 415 thread if they use the same needle and hook? Last - What about the 3500 is this the compromise?
Yes I do plan on calling Toledo - but also looking for what others may have gone through picking there first NEW machine.  Thanks
It seems I've either missed it, or no one has asked... what do you plan to sew mostly?  I have both machines, and a lot of stuff the 4500 simply won't do for me because of the thickness, such as one layer of <4 oz leather to canvas.  I suppose if you were an expert and could finagle the machine, it might do it.  Otherwise, the smaller machine is the tool for the job.  I even have difficulties getting the tensions right on that one with this combination.  However, once you have to double up and have 2 layers of leather and 2+ layers of heavy canvas, sometimes the little machine won't step over the hump so to speak.  All this being said, I am far from an expert, only having struggled to sew a few things on the machines I have.  Just thought someone should pose the question "what is the intended use of the machine?"
YinTx
YinTx
I decided on the CB4500 since it will give me the most versatility, the longer arm, the higher lift, ect.  I will be sewing an average of 1/4 to 1/2 inch most of the time so the CB3500 would have worked but I think I would have tried to push it sometimes and then ended up getting frustrated.  I know this because I did this with my 111w155, I kept trying to run heavy thread and bigger projects than the machine is meant to handle.  I could get it to work sometimes, but other times I would just get the machine clogged-up.  So rather trying to force the machine to go beyond the limits I took the advice and got a machine I could grow into.
I am sewing leather and canvas bags and organizers (I need a better name for that).  I have been looking the last few years for a Singer 97-10 or Singer class 11-22 or similar,  I have not been able to find them locally for any reasonable price so I decided to go for a the Cowboy CB4500 since it has all the features I was looking for (plus reverse) in an arm machine, that can also be converted to a flatbed.   I really love the old machines and I will still keep restoring them, but I wanted a dependable machine that could I can use everyday.
The 3200 does not use the same hook as the 4500.  They look very similar in appearance, but the 3200 hook is slightly smaller than the 4500 hook.    Need a micrometer to check it.  The 3200 also uses different bobbins, too.
The 7x4dia-27 size needle used for size 415 thread has a very large diameter and will tend to brush the hook during use.  This is NOT a good thing since it can lead to a hard crash with the hook when the leather deflects the needle.  Basically, it's just too much needle in too tight an area.
Alexander
