Hello,
I have finally found a fair priced Consew 206rb-3 and I'm picking it up tomorrow. I know that it has been sitting for a couple yeas and by looking at the pictures, It does show light rust on the head and I see evidence of rust on the tensioner and other parts. I am planning on cleaning it up myself so that I can save money and buy a servo motor for it.
Does anyone have any advice on where to start, what to focus on and what I should avoid?
Thank you in advance!
Edited by Jer
Machine looks very good. That's rather old dried and discolored oil than rust I´d say - try whipping it off with kerosene or the like. Download the manual and oil it accordingly. Open the faceplate and remove the needle plate and check for lint / dirt and gunk. Open the top plate and check the condition of the timing belt. Thats what I would start with.
Thank you! That will get me started. I appreciate it.
Yeah, looks good, no paint wear on the baseplate that I can see. Slowly rotate the wheel by hand to make sure nothing is binding and everything is moving as it should, if you feel any tightness stop and find out what it is. Remove the bobbin and make sure it's all clean in there. As Constabulary said, get a  manual, must have a manual!
As to what to avoid - DON'T start loosening screws until you understand what you're doing.
Picked up the machine last night. She initially want $350 then told me $250 when I got there. It moves really nicely. Turned it on and engaged it for a sec and it sounded wonderful.
It needs to be oiled though before I start it up again , the reservoir is empty and the oil pan is full.
I'm unable to locate a online manual containing oiling instructions for the rb-2, Found a rb-1 and 5 though. Hoping the local shops here in Minneapolis have one.
Thank you for the replys.
