Leatherworker.net
Sketch book cover from Veg tan, hand dyed and stitched.
I had an issue with the left inside piece, it had shrunk enough after dying that it no longer fitted, so a patch was made and attached.
There is a little residual wax on the surface that is visible in some of the pics.
Looks really good and that patch works, if that happens again do the same on the other end.
  • 2 weeks later...
I should have cut and stitched it back together  to make it look patched!
