I'm considering making a gun belt for myself over winter, I know it would be cheaper to buy one, but what's the fun in that... Anyway I know I need to make it 2 layers then stitch together, but what weight should I use and what part of the hide?
Thanks.
And any other tips are appreciated
Just like everything else, it depends.  What do you intend to carry? Where are you intending to carry it.  Is it for concealment or open carry.  Big (heavy) pistol or belly gun?  Give us a bit more to go on so we don't send you down the wrong road.
I usually carry either a 9mm or a 38 special on the own and cover it with my shirt. I'm about 150lbs soaking wet. I don't carry big guns
Then I'd think a 7 oz firm leather should work if you're going to line it.  Probably just a 1 1/2 in straight belt, I'm assuming?
Yea I thought people stitched two pieces together so it was stiffer. Idk
If you really want to line it, go with 2 layers of 5oz. That way you are only buying 1 piece of leather. 10oz for a small gun should be more then enough. If not, get a piece of saddle skirting (12-14oz) and line it with 2-3oz veg tan
Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
You can make it as stiff as you want, but it all depends on what you want the final result to be.  If you want a dress belt that you can hang a holster on, it's one thing.  If you want to have a drop rig for quick draw or show, it's entirely another. There is no one correct answer until you define a few other parameters.  Are you intending to carry a sub-compact 9 mm inside your waistband or a full sized 9 on your hip?  Want to add magazine pouches? I'd love to help you but I've got to know more.
Everyone has their own preferences of course, but I usually only make mine 1 1/2" wide so that they fit in all pants instead of just some pants. If the total weight of the leather is at least 10oz you will be fine. 12 oz is better. If I know its going to a guy who carries I usually put a stiffener between the belt and the liner. Just some poster board works fine. I'm not sure the stiffener is really necessary but its easy to do. Good luck!
yea ill be carrying a sub compact 9mm or a 38 special. sometimes iwb sometimes owb. occasionally ill add a magazine pouch.
sounds like overall 10-12 should be ok from what im reading.
should i get a belly or back cut? which will end up being stiffer?
