Members DrmCa Posted November 4, 2017 Members Report Posted November 4, 2017 Was shopping for bobbins and came across a listing on Ali Express where the seller was showing 22 x 12.6mm bobbin with a 6mm hole. The bobbins I am currently using are 22 x 9mm with a 6mm hole. Is he wrong or does my machine have a wrong bobbin case and hook assembly? Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Uwe Posted November 5, 2017 Report Posted November 5, 2017 Pfaff 335 machines come with different hook sizes depending on vintage and subclass. Modern Pfaff 335 machines have a 40% larger hook. Just get whatever is in your machine now. Shop by part number if possible, based on the parts diagram for your specific machine subclass and vintage. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members DrmCa Posted November 6, 2017 Author Members Report Posted November 6, 2017 Mine is the old casting -17, so I get the small bobbin then. Thanks again! Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members solowiej Posted August 6 Members Report Posted August 6 Just to leave this info here: I needed a bobbin case for my 840-100. Many claimed the same style and measurements, but the one that finally fit just right is called: Cutex Bobbin Case #173058 for Singer 206W, 306W, 319 Sewing Machines So #173058 is the winning number for smaller 335 machines (not the 335G with larger bobbin) It's also worth noting that the larger 335G bobbin hook set does install nicely to the 335 machines with no other parts changing. If you need to shop for the right bobbin case, it may make sense to replace the whole set and take the upgrade. There are plenty of inexpensive hook sets for both models. The higher end original Italian-made ones appear to be these: Large Bobbin for 335G model and clones: CERLIANI 130.00.335 Standard Bobbin for 335 model and clones: CERLIANI 130.03.017 Quote
