First post here, I'm probably doing it wrong. Please correct (gently :) ) as you see fit...
I picked up a rivet setting tool at an estate sale and don't know what size it is. The hole for setting the burr is .22 inches (5.6mm) in diameter. Can someone enlighten me as to what size this is? I think I saw somewhere that you can use a larger tool on a smaller rivet. Does that sound right? Is the rule of thumb if the post fits it works? Thanks for your help!
Based on my experience, that would be for a very large rivet. I use mostly #12 rivets, approximately 3 mm) the setter just fits the shaft. You need a very close fit for the tool and rivet shaft so the burr does not "cone" when being set. You want to keep it flat. That size setter would be about a #7 rivet (if it exist). #8 rivets have a 4.5mm shaft.
Here is great video on copper rivet setting.
Eric Fisher
Fisher Custom Leather
"A Retirement Project"
https://fishercustomleather.wordpress.com/
I really don't know anything about those type rivets. I haven't used them yet.
But if it's .22" I would guess that it would be for some heavy harness tack.
are you sure its for copper rivets? I've seen people use brass casings from .22 LR caliber cartridges as rivets. always wanted to try it.
