So after trying to stitch a few times with the Shetland Pony (Thank you Thor's Hammer Milinior???) I have decided to actually create something to stitch on.
There are many designs I can find online. The question I have is...
How wide at the top?
All the ones I see are only about 4-6 inches wide. I certainly expect to make mine at least 6 inches wide/long.
Should I? or is there a reason to keep it thinner?
Also, is there a name for the type of thing that can be adjusted (threaded rod) but then you just lever it up or down and it's locked? I would love to Google that and use it instead of just a wing nut type thing.
Also, I  you have a link online to one you chose and built and enjoy I would certainly accept that.
I have plenty of 1x9's, 2x6 & 8's, 2x4's plywood etc etc
I have basic tools, so this cannot be fancy
Remember, Whether you think you can, or think you can't. You're Right!
Tell me and I forget. Show me and I remember. Involve me and I understand.
It is in the religion of ignorance that tyranny begins
Whoops
I think I want a clam?? Not a Pony.
So I would sit on a board on a chair. I do not want to make an entire bench.
Sled
Well I built a "Hony". Combination Horse and pony. Basically a pony with an extension to make room for my not average gurth.
Mine is 4.5" wide because that was the width of the pine board I made it from.
Here is the link to the Cam Leaver you speak about http://www.leevalley.com/en/hardware/page.aspx?cat=3,43576,61995,61993&p=61993
Couple of pics of what it looks like. Fancier than it needs to be. That thumb knob for the rotating head is also from Lee Valley. http://www.leevalley.com/en/hardware/page.aspx?cat=3,43576,61995,61629&p=61629
Hope this helps.
Eric Fisher
Fisher Custom Leather
"A Retirement Project"
https://fishercustomleather.wordpress.com/
Exactly what I want.
Since posting my question earlier I have almost finished cutting 2 out. but when testing my "Girth Adjustment I realized it needs More adjustment
I found everything just walking through my house. All the wood, some bolts, hinges.
I will definitely be ordering those 2 items you posted,
My plan is to create a padded 1x10 of correct girth adjustment.
Attached to 2 2x4's with their outer edges made 1/2 round with a router. a 2x4 between with a hinge on 1 of the 2x4 towers, and at the top 2 pieces of 45 degree 1x3 cedar 8 inches wide that I found in the basement.
So very similar to yours, but with an 8 inch jaw
8 hours ago, MakerUnknown said:
In my universe, anything that can catch a thread will catch a thread.  I'll search tomorrow for some pics of my futile attempt to to circumvent that law.
I have been fighting that for over a year. Her Name is Quinn. she is 1.5yrs old now but still a kitten. if she sneaks in the room anything is game!
If I understand YOUR meaning its sand and seal everything?
Ha!  Hadn't thought of a cat. But yes.  I pulled this out of another thread on the subject awhile back.
5a4e5d100bd9a_ScreenShot2018-01-04at8_56_14AM.png.57a566cf81b38a305503a4a5b18d5360.png5a4e5d119d5e8_ScreenShot2018-01-04at8_56_05AM.png.1046ccc79c4a86ebbb213124676fcd1e.png5a4e5d130312b_ScreenShot2018-01-04at8_55_43AM.png.320a33468573bdaeddc50f6a33f2b236.png
Although I don't think this is finished, this is how I built mine and use it.
I wanted to accomplish a couple things with the design.
I didn't want something running through the body of the horse as the method of clamping. I think a bolt running inside the horse would get in the way if you needed to clamp a longer piece.
I didn't want objects on the outside of the horse that would catch the loops of thread while sewing.
And I wanted a quick way of applying pressure and releasing the pressure in order to move the piece.
So what I came up with is this. A thin flexible piece of wood that exerts the side force by being in tension. It works. There's a wide range of thickness it will accommodate within it's range. I lift up to release pressure, move the leather, release the thin board and the pressure is right back on it. I clamp the whole horse to my workbench and work standing up. I don't own a TV and have no need to sit and watch something while I'm stitching....it's better for you anyway to stand.
So far loops of thread run on it without catching onto anything.
I say it's not finished because I want to come up with a system that I can change the anchoring point for the lower part of the thin flexible wood quickly without needing a clamp.
That looks great, and the no catching on handles is a good idea. But that looks too something for me, hard to say for sure, I think I would break the thin pressure board. I have a habit of over tightening many things.
I do own a TV but do not watch while stitching. I do listen sometimes, but mostly its music in the background.
I would consider something like that (Standing and nothing in the center) when I move up to real bags.
I have cut enough pieces for 2 clams already, and even found some of the star nuts mentioned above just laying in a tool box. I just needs some bolts for now...
Naturally I am already thinking of a way to upgrade it.
how do you determine the angle and length of board to use in your design?
Sled
Do you think that system would work and 2 4ft tall pieces of 2x6 cedar?
What wood would I use for the flexible part that gives the pressure? My creativity wheels are in high gear.
Sled
4'?  I don't see why not but you would need a large distance away from that for the "go bars".  It's a very old method of clamping, using something under tension to apply force.  They're used in framing walls on a house to not only position the wall vertically but if you need to pull or push the middle sections.  Go Bars sold here to be used here in luthier applications.
Which material you use would be an experiment for you. Something rigid enough but flexible..Sounds like a Zen koan.
Edited by MakerUnknown
To insert the word "the"
