Where are you fellas getting your rubber pads?
I'm in the process of setting up my new Weaver bottle jack press. I plan to use the press for both molding my holster/sheaths and clicking out holster parts. My 1" gum rubber pads arrived today. Now for the questions
1. If I'm going to mold only the face side of a holster, I assume I mount mount rubber pad on the top (moveable) plate and press against the non padded bottom plate. Am I correct?
2. What method is used to attach the rubber pads to the plates so they can be easily removed for clicking parts, or do I just set the pad on the bottom plate and hold the pad on the upper plate while I lower the ram onto the holster?
Thanks for your help!
Randy
Randy,
Can that gum rubber pad you have be cut into as easily as the Tandy poundo mats? I'd like to find a good gum rubber pad that I can put on top of my 55 lbs. anvil for stamping out logos with an oval die and heavy hammer.
Ed
Randy,
Ed
NOT Randy...but I would not think this would work very well as the rubber would not give a stable underpinning causing the stamp to bounce when you strike it with the mallet giving you multiple impressions.....just a thought anyway.
Brock Morgan
Bluegrass Holsters
www.bluegrassholsters.com
The rubber is soft and is utilized to form the leather around an object I think. About an inch or so thick from what I have read about using press for moulding rather than clicking. If clicking a steel plate and some type of cutting board material would be used. Jordan
The poundo boards work very well, but they cut too easily.
ed
