Members ELeBlanc Posted January 17, 2018 Members Report Posted January 17, 2018 thinking about buying the machine but can't use a clutch motor. Quote
Members Yetibelle Posted January 17, 2018 Members Report Posted January 17, 2018 No issues, swapping the clutch motor for a servo motor, assuming the clutch motor was mounted in a standard 3 bolt standard setup. If not you may have to drill a few new holes but that's not a big deal. The Servo motor is a huge improvement over the clutch motor, you wont regret it. Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members JeffHami Posted January 19, 2018 Members Report Posted January 19, 2018 I converted a 153W 100 over to a servo with no problem but I did find I needed to install a speed reducing pulley so I could drop the speed down slow enough to do leather. Quote
Members dikman Posted January 19, 2018 Members Report Posted January 19, 2018 Try and fit the smallest pulley you can find to the motor - 2" or less - as it all helps. You'll probably need a shorter belt too. Just watch the weight of the clutch motor when you remove it, they're heavy!! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Mizzy Posted May 19, 2018 Members Report Posted May 19, 2018 Hello, sorry for coming in late here. I’m about to put a servo motor underneath my 153w103, but I’m hesitating. Will a Doso DS 28 (3/4 hp) servo motor suffice, or do I need more grunt? Any advice will be greatly appreciated. Quote
Members dikman Posted May 19, 2018 Members Report Posted May 19, 2018 3/4 hp should be fine. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members ELeBlanc Posted November 17, 2019 Author Members Report Posted November 17, 2019 On 5/19/2018 at 5:17 AM, Mizzy said: Hello, sorry for coming in late here. I’m about to put a servo motor underneath my 153w103, but I’m hesitating. Will a Doso DS 28 (3/4 hp) servo motor suffice, or do I need more grunt? Any advice will be greatly appreciated. Did you end up doing this and how did it work? What Servo did you use? I'm looking at a 153W103 now... Quote
