  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
41 minutes ago, T Moore Medicine Hat Saddlery said:
What machine ,foot,and plate combination will allow you to sew the closest to buckles on headstalls. I think a new machine or nearly new is on order
Are you wanting to sew forward as far as possible towards the buckle and back up, or sew across the leather to close the buckle in?
If you want to sew up to the buckle and back, a single left toe, or double toe "harness foot set" on a 441 clone will do that. To also sew across the plane of the buckle, the left only toe foot will place the needle within 1/8 inch of the tightly folded leather.
Any throat plate you get with that machine will do. I use a Cowboy CB4500 for these kinds of jobs. I also use it to sew holsters, gun belts, knife and axe sheathes, bridles, saddle fleece relines, belts, et al. I have a good friend who uses a Cobra Class 4 to sew all of the commercial leather goods he sells, including holsters, rifle slings and guitar straps. These machines come stock with a narrow harness foot set.
You can also get very close to buckles if you have a Union Lockstitch or Campbell Lockstitch machine with a short toe foot.
Posted IMHO, by Wiz
What machine are you now using to sew these buckles? Can you show a pix of the buckle you have problems sewing, under the foot?
Posted IMHO, by Wiz
14 hours ago, T Moore Medicine Hat Saddlery said:
Using a pearson #6
So, you have a flat throat plate on it? Is there a raised plate (stirrup) available, or can one be fabbed?
Posted IMHO, by Wiz
My Union Lockstitch machines had raised throat plates that allowed me to get really close to buckles, even center bar types. You could probably have one made that is just long enough to let the needle and awl move the leather, then drop off fore and aft.
Posted IMHO, by Wiz
It's the design of the machine you are using that makes it difficult to sew up close to a center bar buckle. The design is very similar to a Landis 1 and a Bauer, and is the main drawback to those machines.  I'm not aware of any plates available for these machines to allow easier sewing of that type of buckle.  Greg Gomersall is very knowledgeable on the Pearsons, and would know if there ever were raised plates available for them.  As Wiz mentioned, a Campbell/Randall type of machine (Landis 3 is very similar in design), or a Union Lock, Landis 16, makes sewing up to those buckles much easier.  Second would be the 441 type machines. Because the cylinder arm is flat on these machines, they are not quite as easy to sew the center bar buckles on as those previously mentioned. While raised plates are available for the 441's, you loose height capacity.  I nearly always sew that type of buckle in with a "fish" type of pattern; Start up as close to the buckle as you can, cross over diagonally and sew down the lap to a point, turn your work and sew back up, crossing over again to the opposite side when you get near the buckle.  It takes some practice to get proficient at it.  Never, ever sew straight across a strap on anything designed for equine use.  You basically create a "tear-line" for the strap under stress.  You can sew straight from and back up to the buckle, but won't be able to get as tight of a fit.  Loose hardware in the tack business equals sloppy work.  I put a wedge in at almost every piece of hardware when I'm building harness.  The tack industry has become flooded with budding "tack makers" since the Chinese clone machines became easily and cheaply available.  The sewing by some of these people is horrendous. . . they know absolutely nothing about basic construction principles.  Their goal is to produce flashy, blingy tack for the barrel racing crowd.  I guess if the stuff they are making lasts long enough for the fad to fall out of fashion, then it probably really doesn't matter.  I just can't bring myself to cut corners.
Hi Big Sioux could I see a picture of the "fish" sewing you mention please Sorry I am having a hard time with the visualisation.
What machine are you using to do this on as well.
Regards
Johanne
Johanne
"Learn the rules so you know how to break them properly"
Regards
Johanne
Sure I'll find something and get a pic.  The "fish" pattern is just my own term, I've never heard anyone call it that before.  I figured it would make it easier to visualize, but apparently, I failed. I've sewn them on a Randall, Union Lock and a 441 clone.  Randall would be my first choice. Besides of the fact that their design facilitates sewing close to the buckle, there has never been another machine that can lay down as pretty of a stitch. Landis 3 is a close second of the hook and awl machines. Union Locks can be a tough machine to get along with. They are made for high speed production, as opposed to a small shop that does many different kinds of work. But the design of the throat makes it easy to sew the center bar buckles.  Currently I have been using a 441 clone, only because for the past 6 years, until this last month, I have been seriously limited on space. I needed to use the space I had available for machines that were the most versatile. I do a moderate amount of synthetics sewing, and the hook and awl machines can't sew synthetics.  So I had the clone set up, and another heavy machine to specifically sew rounds and tugs (Landis One).  Before too much more time goes by, I will have all the machines I own set up and useable, without spending a half day moving stuff to get to them!
