ke6cvh Report post Posted January 24, 2018 (edited) Hello group, We are using a recently overhauled circa 1915 Singer 45k1 allot lately and love the machine for heavy type work with webbing, canvas, and denim. I took the low road and got a locally available 750w brushless servo as the price was just over 100 dollars in this country. It is nice enough but I've seen problems with this brand of motor wanting to chug along at the lowest speed when letting off the pedal and not stopping ever. It was a case of supply and demand...low cost and easily available. Lots of messing around got it to work properly again (motor stopping after letting off pedal) and I noted the problem went away when I messed with the needle up/down button. My assumption is that the circuit board/micro controller circuitry is confused thinking it needs a sensor input so it is hunting and waiting for the sensor to tell it to stop. This was partially confirmed by shorting two pins on sensor input connector resetting the board. So I spent under 20 US dollars (850 Philippine pesos) and got a sensor and hooked it up. Well the motor no longer gets confused with the up/down sensor button. However the heavier weight of the flywheel allows it to freewheel past the up or down position hahaha. Inertia of heavy hand wheels and needle position sensors just don't seem to be made for one another. I thought this motor had a brake on it like the ones that Bob Kovar sells but it seems to not be the case. Anyone have similar humorous but not so good experience with motor position sensors? Maker of motor is CHM and of course China mfg. for motor. Best regards, Mike Edited January 24, 2018 by ke6cvh Quote Share this post Link to post Share on other sites
CowboyBob Report post Posted January 25, 2018 Mike,all the brushless have an (electronic brake) not mechanical like the motors you bought from me.We had a lot of problems with the brushless with the boards burning out & stopped selling them yrs ago. Quote Share this post Link to post Share on other sites
