Members ContactCement Posted January 25, 2018 Members Report Posted January 25, 2018 (edited) I'm crafting my own professional burnishing tool. The heavy scrap leather shown is for show and what I might attempt to use for a stacked leather handle. I however I don't know what kind of grab bag scrap leather it is and have never made a stacked leather handle. I recently made a heavy leather smoother. I still need to choose a handle material either wood or stacked leather or plastic. I purchased and recycled a 1" thick scrap stainless steel disc 2 1/2" diameter that weighs 1 lb 6 oz. I don't own a metal lathe. No metal lathe was used for my project. The scrap stainless steel disc was already machined to size and had machining marks left when it was cut to length. It took 4 hours using wet dry sandpaper, water and my granite surface plate to flatten it. I drilled and tapped for a bolt hole exactly on center. The tiny little gap near the threads is from using a counter sink to remove the burr. I cut the head off a straight bolt then put it into my drill press on low speed to file the radius and polish the edge. A buffing wheel on the bench grinder was used for the final almost mirror finish using Red Rouge. Your opinion counts should I make this into a maul and smoother combination tool? Would I make another one of these? Yes it was time consuming, inexpensive and fun. Edited January 25, 2018 by ContactCement Quote
Members Sanch Posted February 23, 2018 Members Report Posted February 23, 2018 How do you intend to use this as a burnisher please explain Quote
Rockoboy Posted February 24, 2018 Report Posted February 24, 2018 Great job on the finish. Is that threaded rod (bolt shaft) going to be strong enough to hold the weight, especially if its going to be used in/on a machine driven burnisher? Quote
Members zuludog Posted February 24, 2018 Members Report Posted February 24, 2018 I don't see how this is a burnisher. Are you sure you don't mean a leather fitter's hammer or smasher? Whatever it is, you've done a good job; it would be nice to see it when it's finished Quote
Contributing Member fredk Posted February 24, 2018 Contributing Member Report Posted February 24, 2018 Will a stacked leather grip be enough around a bolt that size diameter? Perhaps a wood handle might be better Chaps, He's making a burnisher that looks a bit like this; https://www.tandyleather.eu/en/product/craftool-pro-leather-burnisher Quote
Members zuludog Posted February 24, 2018 Members Report Posted February 24, 2018 Ah, now I see; thankyou Why not ask around to find a woodturner or a woodturning club to make a wooden handle? That sort of thing is meat & drink for them Quote
