HardenGoods Report post Posted February 14, 2018 Hi everyone, I was hoping to gain some knowledge from some of the Adler experts out there. I’ve got an Adler 067 GK-373 and I’m having trouble with the thread tension. The trouble is not that my knots come up through the top all the time or the bottom all the time, but rather, even after dialling in the correct tension on a scrap piece from the same leather/project I am about to sew, I still get intermittent knots on the top and on the bottom (in the same run). They only show up every few inches and it seems to be worse when I am graduating from one thickness of leather to another (eg. wallet pocket layers), but they show up on straight stitching single thickness pieces too. I’ve scoured these (super helpful) forums and internet at large but nothing has worked. Things I’ve tried: - changing thread - following the thread path through the machine to make sure machine is threaded properly - watched the machine as it was sewing to make sure there are no snags anywhere - ensured that the thread cone is letting the thread off without snags - changing feet - holding thread back at beginning of stitch run - making sure I’m not accidentally touching knee lift at the wrong time - brand new bobbins - ensuring that bobbins are wound properly (as per manual and not to one side) - increasing bobbin tension and decreasing top tension - decreasing bobbin tension and increasing top tension - changing needle (in relation to thread size both up and down) - machine timing (as per Use Grosse super helpful videos on youtube) - I have throughly read the english translation of the mechanics guide for the machine and configured it exactly as the manual has suggested (eg. check all screw seats, needle entry, hook adjustment, needle guard, needle bar height, presser bar timing and height, feed dog timing and height, needle feed, top feed, foot lift height, check spring etc). - not lifting presser foot any higher than needed to release the fabric on turns - proper oil and consistent oiling The only thing I feel I have not tried is adjusting the bobbin case lifter but it doesn’t seem to be off as per the manual suggests. Below are two photos of the same piece/same run with problems on both the top and the bottom. I’m going nuts over this and it is slowing down my small batches tremendously. Any help would be sooo very much appreciated! Quote Share this post Link to post Share on other sites
Constabulary Report post Posted February 14, 2018 43 minutes ago, HardenGoods said: The only thing I feel I have not tried is adjusting the bobbin case lifter but it doesn’t seem to be off as per the manual suggests. Guess you mean the bobbin case opener - that would have been my suggestion. I´m sure UWE has a YT Video how to adjust it. I would probbaly try to increase both top and bottom tension a bit and I´d also play with the tension of the thread regulator spring (check spring). Just a guess w/o sitting in front of your machine. Quote Share this post Link to post Share on other sites
Trox Report post Posted February 14, 2018 When something like this happens it' often because the top thread suddenly get a brake or bottom bobbin is uneven winded. To make the top thread tension stabil you need to make sure of the following factors.... On the thread rack...(use left twisted thread, it usual left twisted) the thread guide on top of the spool must be placed exactly over the center of the thread spool/cone... If it off center you will have uneven top thread tension. Make sure you thread it true at least two holes in the top pin post guide....you can even apply more tension by use several holes....this way you will have a stabil top tension....Bobbins must also be evenly winded... good luck! Quote Share this post Link to post Share on other sites
HardenGoods Report post Posted February 14, 2018 2 hours ago, Constabulary said: Guess you mean the bobbin case opener - that would have been my suggestion. I´m sure UWE has a YT Video how to adjust it. I would probbaly try to increase both top and bottom tension a bit and I´d also play with the tension of the thread regulator spring (check spring). Just a guess w/o sitting in front of your machine. I will double check the thread regulator spring (check spring). I watched UWE's check spring video a couple of weeks ago and adjusted it then but it didn't seem to change much. I think I'm going to try adjusting the bobbin case lifter (thats what the manual calls it) and see if it helps. Thanks for the feedback Constabulary, I really appreciate it. 2 hours ago, Trox said: When something like this happens it' often because the top thread suddenly get a brake or bottom bobbin is uneven winded. To make the top thread tension stabil you need to make sure of the following factors.... On the thread rack...(use left twisted thread, it usual left twisted) the thread guide on top of the spool must be placed exactly over the center of the thread spool/cone... If it off center you will have uneven top thread tension. Make sure you thread it true at least two holes in the top pin post guide....you can even apply more tension by use several holes....this way you will have a stabil top tension....Bobbins must also be evenly winded... good luck! Trox, that is one thing I have not tried (using several holes in the top thread pin). Will also look into the thread guide in relation to spool. Thanks a lot for the input! Quote Share this post Link to post Share on other sites
Trox Report post Posted February 15, 2018 Yes these are important factors, you will get a more consistent top tension threading true several holes. You probably got to ease of on the thread brake, thought. When you the thread knot laying on the top and it suddenly happens in the middle of the seam, those are factors I would have looked out for. Could be caused by uneven bobbin winding or bobbin case opener too, but then perhaps more frequently and probrably with the knot on the bottom. However, everything must be correct...check all thread paths for chips in the metal etc. Good luck! Quote Share this post Link to post Share on other sites
HardenGoods Report post Posted February 15, 2018 2 hours ago, Trox said: Yes these are important factors, you will get a more consistent top tension threading true several holes. You probably got to ease of on the thread brake, thought. When you the thread knot laying on the top and it suddenly happens in the middle of the seam, those are factors I would have looked out for. Could be caused by uneven bobbin winding or bobbin case opener too, but then perhaps more frequently and probrably with the knot on the bottom. However, everything must be correct...check all thread paths for chips in the metal etc. Good luck! Yea, I am going to cover all bases for sure. In some ways this is good because it's forcing me to learn every square inch of my machine. In regards to the bobbin case opener (now that I know its' correct name), am I just adjusting the set screw to allow the width of thread I am using to pass through and no more and no less? Also, do you think this groove in the bobbin top case could be causing it? Not sure of the groove was placed there by manufacturer or if thread has rubbed its way in over the decades. Thanks Trox! Quote Share this post Link to post Share on other sites
Uwe Report post Posted February 15, 2018 21 hours ago, HardenGoods said: bobbin case lifter (thats what the manual calls it) Ah, the joys of technical translations. I'm sure the manual actually does call it that, but it's really just a case of a poor translation of the original German term "Spulengehäuse-Lüfter," where "Spulengehäuse" means "bobbin case", but "Lüfter" only sounds like "lifter." (similar to another popular mistake like translating a phrase like "Ich bekam einen Computer" as "I became a computer" instead of "I got a computer.") The function of the part is to open a passageway for the thread, not to lift anything up. "Lüften" means, among other things, to open a passageway. Sometimes you do lift something up to open a passageway, but not really on bobbin cases. So, rather than perpetuate an instance of poor translation, it's better to use the term "bobbin case opener", which is the term generally accepted and used in manuals that were authored in English and not translated from some other language. There you have it - more than you ever wanted to know about that obscure detail. As for the groove under the bobbin tension spring on the bobbin case cap, it may be getting worn but I doubt it's bad enough to cause a problem yet. It's really the tip of the spring blade that provides the bobbin thread tension (unless you overtighten the spring blade adjustment screw). Two of my Adler x67/x69 bobbin case caps have similar grooves, but to varying degrees. New replacement caps are not cheap, I'm afraid. Quote Share this post Link to post Share on other sites
HardenGoods Report post Posted February 15, 2018 10 minutes ago, Uwe said: There you have it - more than you ever wanted to know about that obscure detail. Haha, no I'm happy to gain all the correct knowledge I can on sewing machines and you seem to have a lot of it Uwe! That would explain my lack of results when researching "bobbin lifter" too. Very happy to know the purpose of it now as it was the only adjustment out of all of the adjustments covered in the english translation of the 167 service manual that I could not wrap my head around. And you are right, the bobbin top case is expensive.. and most of the parts, for that matter. I'm trying to get my hands on just the thumb tab that releases the bobbin top case right now and was quoted at $110 Canadian plus shipping and tax. Mind you, the tab isn't sold as is (comes with spring, retaining pin, lower case), but still! Quote Share this post Link to post Share on other sites
Trox Report post Posted February 15, 2018 Hi, Yes s Uwe yours have just groves that makes it harder to get tight tension on thin threads. His is worn right true and would cause problems, I would have changed that bobbin house for a new one...You can get them aftermarket for a good price.. You could try to widen/make the hole round again with a small diamond round file or simmilar..But remember it has to be polished afterwards...Use a white ceramic thin stone.... Quote Share this post Link to post Share on other sites
Trox Report post Posted February 15, 2018 27 £ at college sewing machine https://www.college-sewing.co.uk/store/CPHAD68-BOBBIN-CASE-CAP-ADLER-68-HIROSE Not expensive made by Japanese Hirose...they make good parts Quote Share this post Link to post Share on other sites
HardenGoods Report post Posted February 15, 2018 33 minutes ago, Trox said: Hi, Yes s Uwe yours have just groves that makes it harder to get tight tension on thin threads. His is worn right true and would cause problems, I would have changed that bobbin house for a new one...You can get them aftermarket for a good price.. You could try to widen/make the hole round again with a small diamond round file or simmilar..But remember it has to be polished afterwards...Use a white ceramic thin stone.... At this point I will try anything to fix my tensions issues. Feels like I am down to the point where it's a parts problem. Perhaps I will try widening the hole very carefully and then polish off with a high grit stone as you suggest and if it doesn't work lean towards a new bobbin top case.. maybe throw in a new check spring too as they are cheap. Thanks for the link, that is a reasonable price! Quote Share this post Link to post Share on other sites
Uwe Report post Posted August 23, 2018 (edited) edited post repeating myself. Edited August 23, 2018 by Uwe Quote Share this post Link to post Share on other sites
FrancoisLeather Report post Posted August 24, 2018 18 hours ago, Uwe said: edited post repeating myself. Not sure I know what you are saying. You already resolved someones issue in a different thread and don't want to repeat yourself? Quote Share this post Link to post Share on other sites
Uwe Report post Posted August 24, 2018 I had typed an elaborate post and then realized that I had already said the same thing earlier in this topic. I can't delete my own post for some reason, so i just cleared out my own, superfluous post. Quote Share this post Link to post Share on other sites
Mark842 Report post Posted August 24, 2018 Is this problem consistent with different leathers? I notice you said on scrap from the same leather as the project. I chased this problem for months using a specific Latigo. I adjusted everything thing six ways to Sunday and was going nuts. On someones advise I tried a piece of latigo from a different tannery. Problem went away never to happen again. It was the leather not the machine. Quote Share this post Link to post Share on other sites
HardenGoods Report post Posted August 27, 2018 On 2018-08-24 at 7:27 PM, Mark842 said: Is this problem consistent with different leathers? I notice you said on scrap from the same leather as the project. I chased this problem for months using a specific Latigo. I adjusted everything thing six ways to Sunday and was going nuts. On someones advise I tried a piece of latigo from a different tannery. Problem went away never to happen again. It was the leather not the machine. This problem appeared on many different kinds of leather but I can definitely see a particular tannery or batch playing hard to sew. I’m in the middle of figuring this one out I think. I’ve noticed my takeup lever ascending before the thread reaches the 3:00 position around the hook which creates some random/inconsistent resistance, in turn, altering tension randomly. Quote Share this post Link to post Share on other sites
Wellington Report post Posted November 17, 2019 (edited) Hello, all, I have a problem with the upper tension on my Adler 67-GK373, as well – specifically, far too much upper tension no matter what I do. (I figured it would be better to post to this thread rather than open a new one, simply to make it easier for others to resolve upper thread tension issues in the same machine in the future. If moderators prefer I open a new thread, please let me know...) When I'm finished sewing a seam and want to remove the workpiece, the only way I can pull out the thread is by grabbing it below the takeup lever and dragging out enough slack to pull out the workpiece and cut off the threads. The upper tension assembly on my machine has a lever that you press to release the tension to pull the workpiece out of the machine, but the lever doesn't release enough tension -- even when I raise the presser bar by hand, and hold it higher with the knee lever, and push the lever on the tension assembly, and try to pull, the thread breaks, usually at the needle. (This is with T90 thread. with a new #22 needle if memory serves... I can successfully pull 138 thread out (using a #24 needle), simply because it's stronger, but it's still HARD to pull, and probably requires 7-10 pounds of force to pull out the thread.) I tried backing off on the spring tension all the way (even taking off the nut) and that made it a bit better but not much. I disassembled all the tension disk assemblies, degreased, de-varnished, cleaned and inspected. One of the disks on the right-hand spring-loaded tensioner had a tiny, barely visible scratch that might have been made by a grain of sand on the thread. The scratch was barely visible, but you could feel it with your thumbnail, so I polished it out by wet sanding with 400 grit and crocus cloth. I took the upper tension sheetmetal "plate" assembly off and cleaned everything I could reach with brake cleaner and compressed air. (By looking at the back of the assembly, you can see how the lever releases the tension on the bottom right disc assembly.) There are no burrs or grooves that I can feel in the takeup lever or any of the tension disks, or the post on the top of the machine, around which the thread starts its path to the tension assembly. At this point, I'm stumped. Does anyone have any clues for me on what to look at? I've been around sewing machines for a few years now, though this is my first walking foot machine, so this is extremely frustrating to me...I know how to thread the machine and have all the basics covered, I believe, and I think I'm trying to pull the thread out at the right time, with the needle bar up and the takeup lever just beginning to move downward from TDC. (Please ignore the thread in my photos...I was just threading bobbin thread through the upper tension path to try pulling the thread back and forth to try to identify where the bottleneck is.) The machine seems to sew fine, but not being able to release the upper tension is driving me nuts! Thanks in advance for any hints. W. ETA: Does anyone know whether an aftermarket upper tension assembly from a Pfaff 145 will fit here? I see the ones on ebay look a lot like mine...Is there any kind of "standard" that these assemblies conform to, I hope I hope? Edited November 18, 2019 by Wellington Quote Share this post Link to post Share on other sites
Wellington Report post Posted November 26, 2019 (edited) Just to update the thread from my last post: I guess this machine has a slightly different upper tension setup than I'm accustomed to with home sewing machines. I believe Adler designed it so that upper tension wouldn't relax when the presser lifted to climb over big upholstery seams. Bottom line seems to be "you can't loosen it beyond what you can do by lifting the presser by hand or knee, and pushing on the lever just below and to the right of the tension disks, and PULLING." That, and/or pulling thread just below the takeup lever to get enough slack to cut off workpiece. In getting this new machine dialled in to use various threads from 69 to 138 (haven't tried 207 yet), I guess I'm also learning that adjusting bobbin spring tension is just standard operating procedure for these kinds of machines – something I'm not accustomed to with my 201 or 130. With a lot of fiddling and learning along the way, I'm now getting good stitches and learning to live with dragging work out with my feet...so I'm pleased with machine. Reverse stitches don't match forward, especially on long stitches, but I can live with that, too. If backstitch needs to be same length, I can just turn the workpiece or back up a couple of stitches and go over again. Bought a couple of new feet for it, and really looking forward to putting it to work. Sorry for the dumb newbie questions ... I'm sure I'll have more! Edited November 26, 2019 by Wellington Quote Share this post Link to post Share on other sites
Bert51 Report post Posted November 26, 2019 I was to9ld by a friend when I brought my first machine to find some scrap and practice, then each time you change thread practice. When you cut out a new project, before you start sewing get the scraps and pactice with so you know that your stitches are right before you put the needle into your project. Every time I'm in a hurry and do not run some scrap first I get bitten. Si I tell every one to practice. Bert. Quote Share this post Link to post Share on other sites
ZIIK Report post Posted December 8, 2019 Hey Wellington, I believe it would be possible to make your machine release tension when you push/pull the release "button". I believe something is either broken, missing or out of adjustment or specification in this case. The button likely pushes on a plate that in turn push a thin rod through the tension unit. The rod push on a washer with a thin "bridge" across the center hole. Putting pressure from the backside on this washer (the thin centerpiece) is what makes the spring back off to release the thread. The length of the rod is important, and you can make your own if needed. Remove your tension unit again and look at how the button linkage works. Try removing it and the rod. Then try pushing the spring with a thin piece of metal to make sure it moves (a scrap needle works in a pinch). Then you can probably figure out which part that is out of place or if the rod is to short. I'm sure you can make it work. It is just more or less work. Let me know if you require further assistance. Quote Share this post Link to post Share on other sites
