Hi to mechanic specialists !
I'm the owner of some flatbed walking foot machines from Pfaff : one 1245 that run smoothly but also a 545H3 that since I've bought it doesn't work correctly ! It's about to be sure that the machine that I bought in east Spain has suffered a lot at his previous place ...
Without any adjustments till now, the machine sew but with a very low presser foot elevation. When the the elevation screw is settled to his maximal height, the presser foot is only 3 mm above the needle plate (or maybe less ...). If I adjust for an example the elevation screw to it's medium presser foot elevation settle. it just doesn't elevated don't feed the piece of leather I'm sewing !
With the max presser foot screw adjustment :
If I use the presser foot lever, it elevates to it's 14 mm :
I downloaded the technical information of 1245 old cast machine that is close to the 545 but ... It's written in english and I'm completely lost ; I don't even know what lever would give influence in this presser foot elevation !!!
Even if I never worked in adjusting my sewing machines, I'm a somewhat good mechanic using properly the lathe and mill about everyday ... Even if I don't need this machine (Because of the 1245 that work), I would be so happy to fix it because I love the design of this machine.
When I'm not using a sewing machine or a lathe or mill ... I'm building violins !
Waiting for your help, thank you very much in advance.
Greetings from Madrid Spain !
Haderimouve.
I just made a video on the subject of walking foot adjustments for Pfaff 545. Perhaps it will help you resolve the issues with your machine as well:
Uwe (pronounced "OOH-vuh" )
Links: Videos
Wouahhh Uwe, thanks a lot, this is a great video that will help me fixing my machine ! I'm not at home right now, tomorrow morning I will do the adjustments and will let you updated.
Great forum with great people that share their knowledge, thank you thank you !
Hi Uwe, Pfaff mechanic best Guru !
Finally, I was so in hurry to test your adjustments that I went quickly home to "play" with the screwdriver !
First I tried to change the "Factory" eccentric setting : I unscrewed the two bolts and tried to move the axle with the rod : Impossible to move it !!! Maybe with the help of heat ... (The machine is more than 40 years old, everything is very tight on it !), I just gained to loose one bolt in the foundry and spent about half an hour to recover it !
 But comparing your machine's setting  in the video with my machine's actual setting, I realized that this eccentric on my machine was about to be rightly settled.
Then, I had a look to Kryptonite post and read your reply : I tried to settle again according your advices (Compensating the presser foot with 6-7 mm material) and ... Magic ! Now it works superbly!!!!
Thank you very much for your help ... This machine was in a Spanish mechanic shop and the specialist told me that the machine was too old, suffered too much, that the repair was impossible : I was so sad and deseperate because I love this old Pfaff machines ; So many 545 that have really worse state of preservation than mine are working fantastic, smoothly ; I didn't believe the mechanic that told me that the machine was out of order and I was right !
Please Uwe, continue to edit more such videos : With your experience and official technical informations of settings, we are all able to fix our old sewing machines.
If you plan to visit Spain, I would love to invite you for lunch or dinner here in Madrid !
Thanks a lot,
Haderimouve.
  • 2 weeks later...
Thank you Uwe, I always learn something from your tutorials. You are excellent!!
Charlie
  • 3 weeks later...
Thank you Uwe for your great videos.  I learn so much by watching them.
