4 hours ago, crfiremech said:
Garypl:     Awesome Job!  Looks Simple will be making a couple for a Friend.
The color around the center Initials, How did you do that with a airbrush or wool/Sponge?
Thank You for Sharing      ~Hillbilly~
Thanks Hillbilly!
I stamped the  background and initials first, then dyed the whole piece saddle tan.  I painted the initials with Giardini matte paint, then airbrushed the area outside the oval with Fiebings Chocolate dye.  This is an easy project to make - cut 1 piece in a cross shape and stitch up the sides.
Gary
Cowboy 4500, Consew 206RB-4
Thank you so much for the Reply!  I will be making a few of this Case's
This give me the reason to get the air brush Now :)
I sure i will need lots of Practice
~Hillbilly~
Really Enjoying My Hobbies Leather working / Repairing old cast iron.     Still New at it All & learning what I don't know!
Cobra Class 4, Consew p1206rb, Pfaff 1222, Singer 29k60, Mitsubishi db-130gm, juki mo-6743s, Singer 17-23, Singer 29k72, Singer 29k70
Landis 5 in 1, and many others that i repair then sell
http://www.youtube.com/c/HillBillyDesigns         fb.me/HillbillyDesigns
~Hillbilly~
Get the inexpensive ($10) airbrush from Harbor Freight.  The one with the plastic cups - works great and won’t break the bank while you learn to use it!
Gary
Wow! garypl,  I was just thinking about going to Harbor Freight but was not sure what one to get
Now I Know!  It sounds like fun that is trying to learn to use an airbrush
Thank you so much for the GREAT Tip garypl.
~Hillbilly~
Well, I did it. Sort of a "proof of concept, try it on for sizing issues" piece. I put a riveted strap under the "mulligan" sleeves, as I've had more than one loosen up over time, and didn't want the shells to drop out. As it turns out, the tension without it I believe is perfect. It can loosen up just a bit and still be alright. I had some trouble with the tiny camo stamp. Every once in a while it would just sink almost through that thin leather! So, inconsistent shading of a few. I've always had issues with that tiny stamp. Can't see it from where I stand when I shoot, though!
Thanks for the idea!
Jeff
So much leather...so little time.
Jeff
Looks great Jeff!  Did you sew it by hand or with your machine?   I like the idea of using a rivet under the side shell holders - never have to worry about them loosening up.  I might incorporate this in another pouch I am making for a friend!
Gary
Thanks, Gary.
I also toyed with the idea of putting a small rivet at the top of the pieces, where all the strain will be when inserting/removing the box of shell will be. If I was still shooting thousands of rounds a year, I probably would have done that.
I sewed it on my CowBoy 4500. I just bought it recently, and am looking for excuses to actually use it. The forward/reverse areas show it, but I wanted plenty of reinforcement in those areas. Normally, I just reverse three stitches, then go forward for the run, but I just watched a video of someone going forward three, then back three, then forward for the run. Thought I'd try it. Bad idea. It bunches up badly on the back side. I'll go back to the original procedure.
It wasn't "loosening up" that made me use a rivet for the Mulligan strap. It was the tiny area involved. It would have been two stitches with thread. Hardly seemed worth it. It's a judgement call, I guess. It's not a Hermes bag, right?
Still, I won't be embarrassed to wear this at the range. I'll just loop my snazzy home-made belt through it and break-em-all!
Jeff
7 hours ago, alpha2 said:
Thanks, Gary.
Jeff
Jeff, thanks for the feedback.  Agree with you on the rivet use for the side loops.  I stitch my shell box holders by hand because of the small length of the stitch runs and seems easier than bending the box over on my machine to sew it!  I made one of these for myself about 6 years ago and use it 1-2 times a week and other than looking a little beat up, it is holding up great, so I don’t think you would need rivets at the top edges.  (I don’t glue the sides before stitching - just  prepunch the holes and stitch them up.)
Gary
