Hi Guys
I am a newb, be gentle :D
I have just purchased my first machine which I intend to use for Binding edges.  It is a Singer 211/166 which i believe is a half decent machine.
I don't have any service manuals and before i start testing it out I would like to make sure it's well oiled.
From what I can see there is a platic nozzle above a clear oil resevoir. I assume i pull this nozzle out to fill with oil?
I can also see a wick above the needle. I assume this resevoir will automatically drip feed the wick?
Also, what are the main places I should manually add some oil?
Sorry, i am very new to this and just want to make sure I get plenty of work out of my investment.
Cheers!
Many times we can still get a glance of the red paint surrounding some holes on the machine. These are regular maintenance lube points for some sew machine oil.
On the side cover they have a couple tiny plastic covers for lube points. I would rather remove that cover a give it a better service.
When you slide to bobbin cover open, the assembly there needs sew machine oil. The saddle they call one part might still have a dip stick for checking oil level in that particular part. In that a manual can describe these specifics better and its probably best we locate a manual or one from the basic series machine for reference. Does yours have a place on top with site glass showing lube level possibly
Here in the forums search, some tips can be had. Another method is pushing the site through google with a ending of your interest. Like -
site: leatherworker.net - singer 211g166
good day
Floyd
The wick your talking about is for thread lube,which you probably don't need unless your sewing real fast & or heavy material.
Here's a operators manual for your machine.
Singer 211 Operators Guide-Small.pdf
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
cheers Floyd and Bob... That is great info. Also thanks for the guide Bob. That is just what i was searching for.
Hi,
I know nothing about the particular machine you have, but I might be able to help with some other info.
You can download the user manual here - http://parts.singerco.com/IPsvcManuals/211G165_166_265_266.pdf
The service manual here - http://parts.singerco.com/IPsvcManuals/211G165_166_265_266.pdf
A range of manuals are available here for lots of Singer machines -   http://ismacs.net/free-sewing-machine-manuals-list.html#S
These include user manuals, parts lists and some service manuals
manuals for other brands can also be found here - https://www.sewingpartsonline.com/sewing-machine-manuals.aspx
Ismacs is a very handy site for lots of info.
To find out what machine you are looking at on ebay, as long as you have the serial number, you can check out singer serial numbers here - http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html
I have often found that someone is advertising a particular machine, but the serial number tells me that they actually have something else.
That will give you the age of the machine and where it was built, along with the model number.  Once you have the model number. you can look that up here - http://ismacs.net/singer_sewing_machine_company/model-list/classes-1-99.html
That page will give you more specific information about each individual model of Singer machine.  (other brands can also be found on that site).
I hope some of this info will be helpful to you.
Trevor
"Just love preserving that old black cast iron"
Our Current Industrial Singer Machines - 103K;  31M32;  31K48;  31K47;  132K6;  307G2;  17-8;  45K25;  29K58;  and more coming...
Our Domestic Singer machines - 201K (classic style) with knee controlled motor;  201K (classic style) with hand crank;
201K (aluminium body) with foot controlled motor.
struggling to find a date as my serial starts EF, does not exist in that list. looked around but found no info. emailed singer co. to see if they can send me some info.
@loccom
What is the full serial number?  EF....?
All of the EF machines were made in 1949 and 1950.  There were 999,999 in that Serial Number range
Edited by Trevor Baret
  • 2 weeks later...
On 4/10/2018 at 4:56 AM, Trevor Baret said:
@loccom
Sorry for the delay: serial is FE016608  (Not EF sorry)
Sorry - can't help with FE.  I am guessing your machine was probably made in 1950s - with a black ring around the singer logo disc.
Hope the sources of manuals above were helpful.
