A couple more simple wallets.
The first two are kangaroo leather. Each are 3 slots, one has an open centre pocket.
The other has a burgundy latigo back, split to about 1.3mm and then lined with kangaroo leather. Sadly this one is a bit of a second... the outer was a bit thicker than normal and i didn't account enough for it so it ripples a little when closed.
Might be able to save it if I cut the stitching and move the inner over a couple of stitches... but then it'd be uneven, and it works fine as it is... so I'll give it to someone for free instead.
nice work
