JohnD Posted July 14, 2007 Report Posted July 14, 2007 Ed, if the chuck is the type I'm thinking of, it's a tapered fit and should slide into the spindle. A tap should keep it in place, or raise the table up so the chuck will just touch it when lowered all the way down, place a piece of plywood on the table and with the chuck in the splindle (you may have to hold in place) lower the splindle to the wood to press the chuck into the spindle to hold it. I hope this makes sense. If it's the tapered fit chuck it should work. John Quote (rdb):God looked down at the world, and said "See, right there in Witchita, next to the railroad tracks, I didn't put enough dandelions".
esantoro Posted July 14, 2007 Author Report Posted July 14, 2007 Ed, if the chuck is the type I'm thinking of, it's a tapered fit and should slide into the spindle. A tap should keep it in place, or raise the table up so the chuck will just touch it when lowered all the way down, place a piece of plywood on the table and with the chuck in the splindle (you may have to hold in place) lower the splindle to the wood to press the chuck into the spindle to hold it. I hope this makes sense. If it's the tapered fit chuck it should work. John The chuck is a tapered fit (JT33). I retracted the teeth all the way into the chuck and gave the nose of the chuck some light taps to get it stuck on the spindle (arbor?????). This didn't work, as the chuck was easily pulled off. I did a bit of research on the net and came up with the conclusion that the only way to install this chuck is by doing exactly what I've been doing. I went back to the press and this time gave the nose of the chuck some harder whacks with a 2 by 4. The chuck now seems stuck onto the spindle, as it doesn't seem possible for me to pull it off. However, now i am deathly afraid to use the press, because I don't want this 3 lbs chuck flying off and killing anyone, especially me. I don't understand how in the 21st century , this 3 lbs piece of steel is supposed to stay attached just because I whacked it a few times with a piece of wood. In case you don't hear from me again, it was a great pleasure to be a part of this forum. Thanks for all your help. Though my leathercrafting career was shortlived it was lived to the fullest. Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
JohnD Posted July 15, 2007 Report Posted July 15, 2007 I wouldn't be too worried about it, most drill presses, lathe tail stocks and even smaller mills use the tapered fit without incident. Quote (rdb):God looked down at the world, and said "See, right there in Witchita, next to the railroad tracks, I didn't put enough dandelions".
esantoro Posted July 15, 2007 Author Report Posted July 15, 2007 I wouldn't be too worried about it, most drill presses, lathe tail stocks and even smaller mills use the tapered fit without incident. I finally got brave enough to turn on the press today. I love how quiet it is. I'm still a bit paranoid about the way the chuck is just supposed to stay on, so I guess I'll watch it carefully and give it a whack every now and then with a 2 by 4. If I need to remove the chuck, what types of wedges am i supposed to use? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted August 31, 2007 Author Report Posted August 31, 2007 Hi Beez, Again, thank you for turning me on to the drill press. Do you ever have to oil these? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
TZHunter Posted November 6, 2007 Report Posted November 6, 2007 Awesome briefcases ! What is the use of the circle loop under the handle? Thanks. Quote
Members gunfighter48 Posted November 30, 2007 Members Report Posted November 30, 2007 I finally got brave enough to turn on the press today. I love how quiet it is. I'm still a bit paranoid about the way the chuck is just supposed to stay on, so I guess I'll watch it carefully and give it a whack every now and then with a 2 by 4. If I need to remove the chuck, what types of wedges am i supposed to use?Ed I have that same drill press and the chuck will stay on it ok. I have done some heavy wood bit drilling with it and it works just fine. I bought a set of drum sanders at Harbor Freight and use the 2 in diameter one for truing up the edges of my double thickness belts, works great. Quote gunfighter48 A 45 may not expand but it will never be smaller than .45!! NRA Member PSLAC Member
