Members janok Posted August 10, 2018 Members Report Posted August 10, 2018 Missing parts,moving the leather. I try to make that parts, I need the sizes and sent a photo. Also I need a photo of the bottom of the machine-under the machine. Quote
Members DrmCa Posted August 10, 2018 Members Report Posted August 10, 2018 Singer parts are not that difficult to source. Before you spend time and effort making the shaft, try shopping around. These parts can be tricky in terms of surface finish and heat treatment as the originals are often cast iron, not steel. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Evo160K Posted August 10, 2018 Report Posted August 10, 2018 (edited) My 45K25 is disassembled at the moment (see photos above). This is the underside of a 45K53, it may be similar to a 45K25, because the 91163 part you've shown above is common to both subclasses. Others may comment. Edited August 10, 2018 by Evo160K Quote
Members janok Posted August 11, 2018 Author Members Report Posted August 11, 2018 Thank you so much for the good advices! You were very kind! If I have some troubles, I'll ask you again. Thank you once more! Quote
